  • Guests: 39
12/13 williamn (48)
12/13 ReddyK (57)
12/13 Birdman (31)
The Physics Of Propellers (And Electrical Motors).
first  3 4 5 6
Fri Nov 16 2012, 10:08PM
Paint it with a water based paint first. White matt emulsion should do it. Put a few layers on, leave it to dry, then paint with whatever you want. (within reason)
I suggest matt black blackboard paint.
Fri Nov 16 2012, 11:13PM
Ash Small wrote ...
ill try ther Krylon H2O latex spay paint in black, then switch over to other colors once teh base black is dry. im thinking that the ducts should be almost disposable (meaning cheap, and plentiful).
BigBad
Sat Nov 17 2012, 12:40AM
cynical rules lawyering: In this thing, are there constraints on size in flight, or only when being examined?
Sat Nov 17 2012, 05:02AM
BigBad wrote ...
it must fit within a 1m^3 box, (XYZ must be less than 1m), doorways are exactly 1m (39 in) wide, my machine is 29 inchs wide atm. but i can get it down to 22 inches wides with some minor mods.
obviously your a fool if your trying to navigate A 38 inch wide robot through a 39 inch wide opening. The michigan teams bot is about 16 wide and long.
so a wise engineer will realize going to big or too small presents problems for robot posistioning and sensory detection, so therefore ther must be a compromise for an optimised implimentation. (which every team is despreately trying to figure out)
BigBad
Sun Nov 18 2012, 12:35AM
Actually that's interesting; from efficiency POV you'll get extra lift if you go as close as possible to the walls, both sides, because it will interfere with the vortexing.
Also, you want to be as close to the floor as possible, as much as possible; due to ground effect.
Sun Nov 18 2012, 03:12AM
BigBad wrote ...
about the ground effect, there was a team that only used a hover hovercraft bzck in 1989 (or so) so the judges changed the rules, now you have to demonstrate free flight above ground effect, but you can decend back towards the ground later... its just that to complete the task you kinda have to be at about 4 feet AGL, im sure they've arranged it like this on purpose!
Carbon_Rod
Sun Nov 18 2012, 03:15AM
@Patrick
Styrofoam safe spray paint is also at the same craft store I mentioned.
Check the labels to ensure it is specifically noted as such.
@BigBad
Depending on the aircraft, the ground effect can dominate within 1 prop radius of the surface, but in this case would be more closely related to a "deflected slipstream" problem.
Alternately, some craft use shrink-fit adhesive vinyl for skin:
wink
Sun Nov 18 2012, 03:43AM
ive looked into monokote, will use if it becomes advantageous to do so.
right now im trying to figure out how to use Pinky's source on teh use of ducts... 0.03% of a diam is 0.030" fo my prop. so getting the duct to wobble and bend less than 0.060" overall is tricky, though i have made and painted the first duct already.
BigBad
Sun Nov 18 2012, 04:12AM
Patrick wrote ...
BigBad wrote ...
Sure, you should be able to fly at any height, but for example, bouncing up away from the floor, through a hoop or whatever they have, and then going back down and catching yourself right before hitting the floor saves power. Any thrust you generate you want to do that within one rotor radius of the floor; it probably as much as doubles your longevity/halves the battery pack size/mass, or even more, because that's mass you're not carrying, which in turn saves energy which saves more battery; and you can calculate the convergent series.
So it's a control strategy that enables you to reduce the mass.
Sun Nov 18 2012, 04:17AM
BigBad wrote ...
yes ill agree, but that assumes i have a useful 2-D SLAM and decison making model.
first  3 4 5 6
