  • Guests: 34
CT2 (37)
Josh Johnson (46)
01/21 Banana Man (41)
01/21 TheAnomaly (13)
01/23 GimpyJoe (36)
Fuel Cells For UAV Drones
1 2 3 4
Thu Oct 25 2012, 03:48AM Print
Im frustrated with flights of 8 minutes, then 47 minute charge times on expensive LiPo's. Im thinking i need a game changing innovation, that will give my drones capabilities that lipos just cant match.
there have been many manned and unmanned attempts to fly with fuel cells and even manned battery powered aircraft. but so far i only see the crap PEM type fuel cells being used.
heres what id like comments from here on the forum about...
what about solid oxide fuels cells? they suffer only the high heat disadvantage... and the associated 800 degree C insulation. theyer cheaper and dont use platinum and orgainc polymers, which are vulnerable to water flooding/drying out or carbon monoxide poisioning like the crap PEM cells... the solid oxide fuel cells, if small enough, might allow 1 or 2 oz fuel tanks (alcohol or kerosene) to yield 30-40 minute flight times... on a defensive note to skeptics, over the past 15 years SOFCs have come down in operating temp, shortend their start pre-heat time and are cheaper and easier to make.
other opinions? better suggestions for my energy needs? Any important factors i left out?
Thu Oct 25 2012, 03:57AM
One thing worth mentioning is that many modern LiPo cells can be charged at 3C, giving a ~20 minute charge time to 80% capacity.
Per the fuel cell argument, it seems like you would be way better off putting in a small gas/nitro engine, if there is significant electrical load you could even add a generator.
A fuel cell would be cool if you can find one with the power density you need, I am skeptical as to how far you will get though (then again I am a laser scientist and don't know much about fuel cells..)
Thu Oct 25 2012, 06:57AM
I agree, switch to gas engines smile
Ash Small
Thu Oct 25 2012, 11:24AM
Whether you decide to use conventional motors or fuel cells, both of which require a liquid fuel, in your application you'll need to have well baffled fuel tanks in order to prevent the fuel 'sloshing' about, and upsetting stability.
BigBad
Thu Oct 25 2012, 04:00PM
Hydrogen gas fuel cell? That way the fuel has negative weight. You end up with a blimp I suppose, but they do have good hang time.
Maybe try to design your vehicle to fly better; gliders have a much better L/D and can fly proportionately longer. Probably that means a higher Reynold's number though, which probably means a bigger vehicle.
Solar can work, but only if you have a very aerodynamically efficient vehicle.
BigBad
Thu Oct 25 2012, 05:09PM
Beam power is another option, lasers or microwaves; even bright lights would work.
Thu Oct 25 2012, 05:42PM
How about an airframe skin formed from multi-layer organic dye-sentized photocells printed onto textile or paper?
Pinky's Brain
Thu Oct 25 2012, 06:54PM
I presume this is for the quadcopter, gliders don't run dry in 9 minutes.
I wonder how efficient small pulse jet engines are, there is no rotating mass so you can presumably get the same quick power regulation as you get with electrical engines necessary for a quadcopter.
BigBad
Thu Oct 25 2012, 07:28PM
For a quadcopter making the blades longer would greatly improve efficiency.
For hovering or going slowly, jet engines suck balls wrt efficiency. For long flights, everything else being equal, you want to throw a large amount of air down slowly (which is what big long wings do), rather than a small amount of air down fast (which is what jet engines do).
It's because energy goes as 1/2 m v^2, whereas the thrust goes as mv, where m is the mass, and v is the downwash speed; so if you work it you want m as big as possible and v as low as possible, so that mv = vehicle weight
Ash Small
Thu Oct 25 2012, 07:41PM
BigBad wrote ...
Not if it is compressed, which would be the only sensible thing to do. Weight would then be comparable (similar) to other fuels of the same calorific value.
