  • Guests: 48
CT2 (37)
Josh Johnson (46)
01/21 Banana Man (41)
01/21 TheAnomaly (13)
01/23 GimpyJoe (36)
Capacitor Ratings for Pulsed Discharge: Maximum di/dt, Ripple Current and Impedance
cffrost
Wed Oct 24 2012, 02:51AM Print
cffrost Registered Member #5244 Joined: Sat Jun 09 2012, 01:13PM
The context of my post is in relation to pulsed power discharge, specifically as applied to EM projectile accelerators and bridgewires.
I've never seen maximum discharge di/dt specified on any electrolytic spec sheets; can this value be derived from other specs that are usually listed, e.g. ripple current, impedance, etc.?
By the way, is capacitor impedance derived in the same manner as Z for transmission lines? If not, what is it, and does it have any bearing on the applications (above) I'm interested in?
-Thank you
Wed Oct 24 2012, 07:06AM
The maximum discharge di/dt is set by the capacitor's rated voltage and ESL, according to di/dt =V/L.
The stray inductance of the rest of the circuit is just as important as the ESL.
