  • Guests: 32
David (39)
12/25 Kolas (18)
12/26 buxtronix (50)
ZVS Driver voltage output
OnTheWaterfront
Tue Oct 16 2012, 02:05PM Print
OnTheWaterfront Registered Member #7113 Joined: Mon Oct 08 2012, 11:31PM
I have recently built a ZVS driver and a 2n3055 driver for my flyback transformer, the 2n3055 driver gives me about 17kv but gets hot in a hurry. The ZVS driver stays very cool but only gives me about 9.5Kv. Anybody have any tips for tweeking my ZVS setup to boost the voltage output. 24VDC supply L=100uH C=.68uF
Daedronus
Tue Oct 16 2012, 02:27PM
Look at the "DC transfer function"
Microwatt
Tue Oct 16 2012, 10:56PM
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
im getting 25kv out of my zvs.
m4ge123
Tue Oct 16 2012, 11:24PM
m4ge123 Registered Member #4118 Joined: Mon Oct 03 2011, 04:50PM
Take off some primary turns, but I wouldn't go below 6 unless your core isn't hot.
Tue Oct 16 2012, 11:31PM
Andre Registered Member #6921 Joined: Wed Sept 26 2012, 07:47PM
I think decresing the cap to .3uF would increase the frequency to about 30kHz, that might work so it would not overheat.
Dri0m
Wed Oct 17 2012, 04:23AM
Dri0m Registered Member #4497 Joined: Thu Apr 19 2012, 12:53PM
m4ge123 wrote ...
i had 3+3, 4uF cap, 36V input, freq 18kHz and transformer output was so big that arc jumped from gound to HV output (and burned DST from outside), but core and wires can do it for couple of minutes before overheating :)
OnTheWaterfront
Wed Oct 17 2012, 11:27AM
I have reduced my turns to 3+3 and I'm right around, 13kv @ 40Khz. It puts out a fair amount of power just not at a super high voltage. When I draw the arc out more than about 2 inches my 24VDC 10Amp power supply maxes out.
Harry
Wed Oct 17 2012, 10:27PM
Harry Registered Member #4081 Joined: Wed Aug 31 2011, 06:40PM
It may just be the flyback, I've had some before that look identical but one will output nearly double the voltage with the same driver and driver voltage.
Give a 555 driver circuit a go, that will probably get more voltage out of it.
OnTheWaterfront
Thu Oct 18 2012, 10:34AM
I did fail to mention that when using the 2n3055 driver I also utilized the internal primary winding on the flyback.
