  • Guests: 84
David (39)
12/25 Kolas (18)
12/26 buxtronix (50)
after how many turn on a HV transfomer you start insulation
first  4 5 6 7
Wed Oct 17 2012, 08:56PM
Andre Registered Member #6921 Joined: Wed Sept 26 2012, 07:47PM
Guys I want to thank you all, talking to you it did help a lot even if you havent told me the correct formula or how the calculation works , so I will explain them here :)
Steve Conner equation is close enough
V=4*f*N*B*Ae
V=4*60*174*1.81*0.001420m²
V= 106V
1:400 transformer
400*174=69600 Number of turns in secondary
400*110 = 44000V on secondary pick
I will think it average at 35Kv
you guys can take your hats off now cheesey
Sorry, I got the equation wrong: I forgot the core area.
It is just a relation between parameters. The trick is to get to the point where you know all but one. RG Keen wrote this good article on designing audio output transformers, but much of it applies to all transformers. Link2
Tony Matt
Tue Oct 23 2012, 09:16PM
Andre"
Almost fine !
V= 4*f*N*Bmax*
a is a formula for simetrical square wave source
where V is the peak voltage.
If the primary is to be connectcted in your house domestic supply sine wave voltage, use this formula:
V= 4.44*f*N*Bmax*Ae
where V the rms magnitud voltage. (ie 120, 115 volts)
Please recalculate the number of primary turns again.
As Steve has advised, 4.44 is for sine wave voltage.
cheers
first  4 5 6 7
