  • Guests: 40
UHF 300 MHz MOSFET Ionic Plasma Tweeter
zilipoper
Wed Oct 03 2012, 05:36PM Print
zilipoper Registered Member #4152 Joined: Thu Oct 20 2011, 10:18PM
mini plasma tweeter on mosfet:-)
power supply 17v 2.5a
1349285033 4152 FT0 Sam 1988
1349285033 4152 FT0 Sam 1985
1349285033 4152 FT0 Sam 2007
1349285080 4152 FT0 6656
details
VT1 Russian mosfet 2P918A
VT2 UHV bipolar transistor with a current of 100 mA
VT3 2SD718
VD1 1.5KE 18
VD2 1.5KE6.3
C1 0-40pf
C2 0-40Pf
C3 0-3pf
C4 24pf
C5 10NF
C6 10UF
C7 4700UF
C8 100NF
C9 1000UF
C10 10UF
R1 1K
R2 300
R3 600
R4 1K
l3 L4 25 cm piece of wire
GrantX
Thu Oct 04 2012, 04:08AM
Awesome! Very good sound quality, looks like a lot of fun to play with.
Unfortunately, I'm not smart enough to understand what's going on in this circuit :). What is the purpose of that large metallic bar pointing downwards in the 3rd picture? It looks like a thick copper braid soaked in solder?
zilipoper
Thu Oct 04 2012, 05:28AM
an inductor in the form of a coaxial resonator
can be replaced by a piece of wire cheesey
Sigurthr
Thu Oct 04 2012, 02:27PM
Once you get above a few Mhz things start to really take on whole other personalities, especially where layout and reactances are concerned. At 300MHz this plasma tweeter is really quite awesome and truly a feat of engineering!
Avalanche
Thu Oct 04 2012, 10:00PM
This is brilliant! I'm struggling to understand the circuit though, I don't think I've seen an oscillator anything like that before, does it have a name?
I can get as far as the gate bias (R1, R2, R4, VD2, C8, C9) and I can see how VT3 and R3 set the power, with the audio coming in through C10. But everything to the left of C6 is just confusing cheesey
WaveRider
Thu Oct 25 2012, 10:50AM
This is really outstanding. Compliments, zilipoper!!!
