  • Guests: 76
Switching SOA
Mon Oct 01 2012, 09:22PM Print
Was looking at the HGTG20N60A4D datasheet, it says pulsed collector current 280A, but switching SOA of only 100A. Does this mean that when I attempt to turn it off while carrying say 150 Amps, if only once per interrupter cycle, will it really get destroyed? (I guess so, just making sure...)
Datasheets of similar parts often state the switching SOA the same as maximum pulsed current, or don't state the switching SOA at all... So I guess I need to get another similar part with better SOA. Always thought the HGTG IGBTs are rugged, but the datasheet doesn't seem to say so...
Dr. ISOTOP
Mon Oct 01 2012, 10:32PM
It means it can't safely turn off 150A without latching up.
280A is a guarantee on how much the transistor can conduct without ever failing or degrading.
Ben Solon
Mon Oct 01 2012, 11:30PM
so during zcs, you switch off/on at ideally 0A. its only during a hard switch that you need to worry about that rating. and likewise the pulsed current rating is only limited by die temp, so you could theoretically neglect that as well if you could draw heat out of the die very fast.
Tue Oct 02 2012, 07:58AM
Ok, so its like I thought, thanks for the replies...
Tue Oct 02 2012, 11:07AM
The switching SOA is a worst-case figure. It means that the factory's worst die, at its maximum junction temperature and fastest gate drive, will switch 100A without latching up. Most of them will be better, especially if kept cool.
"Latching up": The IGBT structure has a parasitic SCR that can be fired by switching off a high current quickly. Once fired it normally goes into second breakdown and explodes.
Tue Oct 02 2012, 02:13PM
Hmm, guess I'll just have to try it then... cheesey got the 20N60A4D's $3 a piece on Ebay and they even seem genuine...
Herr Zapp
Wed Oct 03 2012, 06:59AM
DDC -
"....and they even seem genuine ....".
What, exactly, does "seem genuine" mean? If you look at the current eBay listings for 20N60A4D IGBT's all but two originate from China or Hong Kong, with an average price of about $3 each. There is ONE listing from the US ($25 each, plus $10 shipping) and one from the UK (~$28 each, plus $5 shipping). Does this not ring a caution bell in your head?
I assure you, the market for "countefeit" IC's and tantalum capacitors is incredibly huge. In the case of ICs, "out-of-spec", production test failure fallout, or developmental lots of components somehow "leak" out factories, then the original markings are glass-bead-blasted off and they are laser "re-marked" with new part numbers or lot numbers. In the case of tantalum capacitors, standard surface mount parts are re-marked as the substantially more expensive low-ESR models, re-spooled, and sold through the "component broker" market. In almost all cases these bogus parts have some basic level of functionality, but perform nowhere near the manufacturer's specs for that particular P/N.
I have had personal experience with both counterfeit SMT comparitors and tantalum caps. During a new product introduction, the first lots of circuit board assemblies (sourced in the far East) worked as designed, but subsequent lots exhibited all sorts of odd behavior. Finally (and visible only with carefully controlled lighting under a stereomicroscope) I found that a tiny SMT comparitor had been "reworked" by having its original markings carefully sanded off, was then bead-blasted to create something that looked similar to the original "as-molded" surface finish, and then carefully laser re-marked. The cosmetic subterfuge was so good, it was only detected when I found one part that had been poorly "sanded", and the original laser markings were still faintly visible under the fresh (but slightly too deep) new laser markings. All this for tiny surface mount parts (4-5 fitting on your fingernail) that cost less than $1.50 direct from the manufacturer.
I would be highly suspect of ANY semiconductor device being shipped from the far East at prices less than the current international market value.
Herr Zapp
Wed Oct 03 2012, 09:27AM
I just got stung by what I believe to be a counterfeit batch of DSP chips. The markings look different to any I ever saw before, and they have a non-existent part number: device rev B, silicon rev 1.1. I think they are a slower speed grade remarked as the 300MHz parts I ordered.
In the case of these fake IGBTs, I think they are older, slower Fairchild devices remarked as more desirable ones. They may still work fine in a DRSSTC.
Wed Oct 03 2012, 02:15PM
Herr Zapp,
I bought these I think Link2
Counterfeits on the other hand usually look like this Link2 (they grind off the original part number and print on a new one)
I'm not saying they are 100% genuine, but they look like the real part. I think I'll do some voltage drop tests.
