  • Guests: 74
IAmSpock (18)
01/30 Ian (37)
01/30 Lucas (40)
01/31 Mathias (42)
CO2 scrubbing and water vapor removal
Wed Sept 26 2012, 11:12PM Print
I plan to suck air through a large pvc tube filled with sodium hydroxide to remove CO2. I know that NaOH and CO2 will form H2O as a byproduct. Still, will the hydroxide also work as a desiccant, or should I have a chamber filled with silica gel beads or alumina?
Bored Chemist
Thu Sept 27 2012, 07:33PM
NaOH is a good desiccant but the question is how dry do you need the air to be?
Thu Sept 27 2012, 08:09PM
I just ordered a molecular sieve that will absorb water and CO2 and hydrocarbons from Delta Absorbers. It's a synthetic zeolite.
Ash Small
Thu Sept 27 2012, 08:33PM
IamSmooth wrote ...
How do you 'flush' it?..... Just bake it, or what?
(I suppose I could look on thir website, but it's late here, and I've had a drink or three.)
Thu Sept 27 2012, 11:08PM
warm it and the water evaporates. keep it less than 350F
