  • Guests: 69
Commissioned Gas Discharge Glow Tubes for SSTCs
Sigurthr
Tue Sept 25 2012, 05:30PM Print
Hey everyone,
A few months ago I was on the hunt for Geissler tubes and the like when it dawned on me that I'd have to settle for small capillary discharge spectrum tubes or find someone to make something custom. So, I chose the latter and did just that! I discovered a glassworker and tubemaker named Ron Soyland who accepted my comission. He even built himself a SSTC to test the tubes out during the production process.
Here is the end result!: Link2
I mis-spoke about the relative pressures in the video as pointed out in the description.
Ron is selling these tubes at ~$70ea and you can choose custom pressures and gas mixes. He has: Ar He Ne CO2 Freon(s) and will accept any pressure of your choice within the safe operating voltage of the glass. I've asked him if he minds my giving out his contact info, and if he agrees I will include it here. For now you can contact him on YT via his channel: Glasslinger
zrg
Tue Sept 25 2012, 06:15PM
zrg Registered Member #4762 Joined: Sun May 06 2012, 05:59PM
Well well well what do we see here :)
I've been doing the same for the last year, and as there are virtually infinite combinations of gases at different pressures, and different mixtures of them with halogens, organics and metal vapours.
You can ask the glassworker to add 1) iodine - gives deep blue color to Ne; 2) ethanol (or other basic alcohol) - gives greenish to argon at high pressures.
Such custom tubes are much harder to break than you think them to be. They survive even high power SGTC strikes w/o exploding (but that may lead to microsized break points which will leak air inside the tube).
Here are some photos from my collection. There are more than 50 such plasma containters different from each other, and thousands of photos and videos, but I'm too lazy to measure and write down the exact mixtures and combinations...
1348596903 4762 FT144928 Dsc 0098
1348596904 4762 FT144928 Img 4376
1348596904 4762 FT144928 Img 4298
1348596904 4762 FT144928 Img 4362
1348596904 4762 FT144928 Img 4378
Sigurthr
Wed Sept 26 2012, 12:55PM
Hi Zrg! Yes, haha, these are the tubes I mentioned when I first contacted you on YT. I can't wait to receive the one you made, your spheres are stunning!
Inducktion
Wed Sept 26 2012, 02:44PM
Hey zrg... I'm guessing you're the glassblower that Sig mentioned? :P
Is there any specific minimum size for these tubes? I had a really cool idea for these.
If you take a smaller tube, and use a sort of "stand" with them, using an AC flyback transformer you can make a display piece for a tube of your choosing, allowing it to run indefinitely and showing off those pretty colors. :D
Sigurthr
Thu Sept 27 2012, 03:04AM
Hehe, no, Zrg is an amateur maker of RF discharge tubes in Russia who I bought from but did not commission.
The glassworker finally OK'd releasing his info;
Ron Soyland - Glasslinger - Link2 and Tubecrafter.com
Just email him via YouTube.
zrg
Thu Sept 27 2012, 12:21PM
I found an interesting mix a few days ago: krypton and... vacuum grease that I use to tighten the connections!
Two big balls made with that mix are really awesome.
I wish I'd had a fellow chemist who would be able to predict the effects of adding different organics, metal vapours and other impurities to the gases...
RateReducer
Thu Oct 04 2012, 07:06AM
RateReducer Registered Member #4603 Joined: Wed Apr 25 2012, 07:33PM
Very nice!
I also tried some things with gas discharge tubes...
Even sealed with electrodes ;-)
Argon:
I was wondering where you got the Xenon/Krypton gas...?
Greetings
Thu Oct 04 2012, 10:57AM
I love this one, is it related to the "weird dots mode" shown on Youtube? Link2
I would seriously consider buying one of these tubes if you'd make me one. :)
Sigurthr
Thu Oct 04 2012, 02:23PM
Gas discharge tubes really do add a whole realm of fun to TCs. After having two of my own and a third en route I can't recommend them highly enough to anyone with a CW tesla coil.
zrg
Fri Oct 05 2012, 08:02PM
A friend of mine made an awesome video today:
and I was making still shots:
1349467267 4762 FT144928 Dsc 5042
1349467267 4762 FT144928 Dsc 5035
1349467267 4762 FT144928 Dsc 5058
1349467267 4762 FT144928 Dsc 5021
1349467267 4762 FT144928 Dsc 5029
1349467267 4762 FT144928 Dsc 5052
1349467267 4762 FT144928 Dsc 5068
all colors are natural as seen by eye and camera (at least in the photos) :)
