  • Guests: 59
Spark Gap Tesla Coil for triggered spark gap
zilipoper
Sat Sept 22 2012, 03:56PM Print
zilipoper Registered Member #4152 Joined: Thu Oct 20 2011, 10:18PM
hi
I had the idea of a Tesla coil for triggered spark gap:-)
this will increase the efficiency of the device and will eliminate the burning of electrodes shades
You may be able to play sound amazed
in your country somebody makes same???? Link2
Here is a diagram, can anyone want to do that?
1348329397 4152 FT0 666
Sat Sept 22 2012, 05:35PM
You'd need an inductor in series with the first set of gaps. Charging one capacitor directly from another one dissipates 50% of the energy as heat, so it would destroy the charging gaps pretty quick.
I'd replace the charging gaps with a SCR stack, or even a triode tube to allow modulation of the charging voltage.
Sat Sept 22 2012, 06:03PM
I think the "standard" DC resonant charging circuit with a diode would work here too.
zilipoper
Sat Sept 22 2012, 06:09PM
electronic lamps are too high internal resistance, and not suitable SGTC
even thyratrons TGI are not suitable for operation in a RSG
triggered spark gap in the scheme are given normalized passport data, and do not exceed the maximum
They will heat up in the order of the norm shades
