  • Guests: 74
IAmSpock (18)
01/30 Ian (37)
01/30 Lucas (40)
01/31 Mathias (42)
solid state marx
Microwatt
Thu Sept 20 2012, 03:28AM Print
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
Is it possible to make a solid state marx generator with reversed diodes instead of spark gaps?
Pinky's Brain
Thu Sept 20 2012, 10:45AM
No, you need something which switches ...
You can make circuits with lc sections connected by diodes which have some similarities with a Marx. You can use diodes instead of resistors in a Marx to charge it (together with a big inductor).
Thu Sept 20 2012, 12:29PM
You can also use SIDACs or SCRs in place of spark gaps.
Microwatt
Thu Sept 20 2012, 02:25PM
But I have seen marx circuits with transistors in avalanche mode.
Pinky's Brain
Thu Sept 20 2012, 02:42PM
So? Those switch from a high resistance to a low resistance state, a reverse diode will only do that if you're willing to let it fail short.
Forty
Thu Sept 20 2012, 03:51PM
would a string of tvs diodes work? since they're kind of like a gas discharge tube
Pinky's Brain
Thu Sept 20 2012, 04:19PM
TVS diodes are not crowbar devices, they are clamping devices ... they are not like gas discharge tubes.
Harry
Thu Sept 20 2012, 05:03PM
Harry Registered Member #4081 Joined: Wed Aug 31 2011, 06:40PM
I was about to suggest gas discharge tubes, it's not solid state but works with lower voltages, albeit not exactly precisely. Can take one hell of a hit in one pulse though.
Pinky's Brain
Thu Sept 20 2012, 06:51PM
So can simple air gaps, they just make a little more noise.
Microwatt
Thu Sept 20 2012, 07:46PM
howabout neon lamps? don't they fire at 50volts?
