  • Guests: 45
01/12 RoV IW3IPD (63)
Anyone know what this is?
Alex M
Wed Sept 19 2012, 10:10PM Print
I have had this in my parts box for a while but I have never really looked into what it is.
1348092471 3943 FT0 Dsc 2381
1348092471 3943 FT0 Dsc 2390
Does anyone have any ideas what this component is? and more importantly how it would be used?
It has the numbers 2322 662 98009 printed on top of it.
Thanks.
Wed Sept 19 2012, 10:28PM
First time I've ever seen a package like that.
Is it electrically symmetric, with two identical disks?
Does each disk have a metal coating on each side?
My bet is that you have MOV's or related circuit protector devices.
Or maybe PTC thermistors as used in motor starters.
1348093566 2099 FT144693 Ptc
1348093674 2099 FT144693 Varistor
Inducktion
Wed Sept 19 2012, 11:41PM
I've seen so many of those thingies inside of TV's, and I've always wondered what they were. It's usually two of those metal disc thingies clamped together...
Adam Munich
Thu Sept 20 2012, 01:06AM
It's either a thermal fuse, or a PTC thermistor.
Probably the latter.
Forty
Thu Sept 20 2012, 03:50AM
I usually see them in little black boxes, but yea, it's probably a thermistor. check the resistance from face to face and then heat it up a little and see if it changes.
Shrad
Thu Sept 20 2012, 08:17AM
PTC, and this one seems to be close to the one used in early 90s philips TV sets... I have also seen similar ones with asymmetric coatings, maybe it had been repaired and some disks replaced
PSCG
Thu Sept 20 2012, 08:40AM
PSCG Registered Member #3792 Joined: Sun Mar 27 2011, 06:07PM
I can too confirm that these components are PTC thermistors (either as a limiter for the initial in - rush current of the SMPS or as a screen degaussing switch). I have opened a lot of these and used the thermistor elements as cheapo temperature sensors.
Alex M
Thu Sept 20 2012, 08:34PM
Thanks for the replies!
Ah I was actually thinking something along the lines of inrush current limiting but couldn't be sure.
Thanks again.
Fri Sept 21 2012, 07:30AM
As PSCG says, it is a dual thermistor from a TV set. One side is a NTC inrush limiter for the power supply, the other side is a PTC to taper off the current through the degaussing coil.
Ash Small
Fri Sept 21 2012, 09:18AM
The Wikipedia page on thermistors shows the schematic for a thermistor as:
1348219105 3414 FT144693 Thermistor
Are there not different symbols for PTC and NTC types?
