  • Guests: 45
12/23 David (39)
12/25 Kolas (18)
what kind of transformer is used in a spark gap ignitor like from sparkfun
jpoopdog
Thu Sept 13 2012, 10:20AM Print
jpoopdog Registered Member #6188 Joined: Wed Aug 15 2012, 08:34AM
i recently went and bought a bunch of these Link2 but of a different model, directly from the wholesaler.
I am amazed by how awesome they are, however, i have no idea on what kind of transformer they use inside.
i really really want to try building my own, problem is its impossible to crack it open and look around inside.
i know its some kind of high voltage pulse trigger transformer, but beyond that name, i cant find anything more, certainly not any transformers i can buy anywhere , no part numbers, nothing! not even sure exactly of what they are called.
does anyone know exactly what transformers would be used in these, and where i can find them, or something similar at least?
thanks.
Thu Sept 13 2012, 06:08PM
theyre generally the same type of transformer as used for Xenon flash lamp triggers, (that might be its original purpose) so it'd be a tiny ferrite transformer with less power throuput then a small flyback.
One more specific difference is, that the smaller HV transformers often use a ferrite slug not a true core.
jpoopdog
Fri Sept 14 2012, 01:06AM
thankyou, i think im on the right track.
though, for what im looking for, what kind of specs should this transformer have, ive looked around a bit and am not sure. like is a 6kv transformer fine? or should i be searching for something at around 20-30kv?
