  • Guests: 100
IAmSpock (18)
01/30 Ian (37)
01/30 Lucas (40)
01/31 Mathias (42)
Homemade foil capacitors
Yanom
Thu Sept 13 2012, 03:00AM Print
Yanom Registered Member #4659 Joined: Sun Apr 29 2012, 06:14PM
I saw this super-cheap homemade capacitor, and calculated that it was about 10^-11 Farads per square centimeter. Not bad, considering it can go up to about 20kV for about .004 Joules per square centimeter. I've also seen this done with foil and wax paper, which I just so happen to have a lot of. Does wax paper give a similar voltage and energy density? I know that it was used for early 20th century capacitors. I want to try this now.
Bjørn
Thu Sept 13 2012, 06:04AM
Yes the results should be comparable if your paper is about the same thickness, but remember that to make reliable capacitors is very difficult so don't expect too much.
There is a lot of information in the wiki about how to calculate the capacitance for different materials Link2
Yanom
Thu Sept 13 2012, 02:39PM
Bjørn wrote ...
There's nothing there for (wax) paper, but I'm assuming that because it's thicker, it'l have slightly less than the 10^-11 Farads per square centimeter that plastic film gives.
But, has anyone here built one of these homemade capacitors before? How well do they work?
Tony Matt
Thu Sept 13 2012, 05:03PM
Tony Matt Registered Member #3700 Joined: Sat Feb 19 2011, 12:59PM
Hi Yanon!
Let me know the exact purpose that you want to use for.
Marx, Tesla, or voltage multiplier power suppy ?
And AC working voltage, dc peak voltage, capacitance.
Cheers
Tony Matt
Fri Sept 14 2012, 12:33AM
Yanom.
The Polypropilene constant dielectrid is about 2.2, and the dielectric strenght is about 20kV/mm (MKS}...
Assuming that the the capacitor dielectric is 0.75 mm thick (five sheets ) and a small air buble 0.1 to 0.2mm thich inside the dielectic or between the dielectric and the aluminun sheets, this buble may be ionezed when the the voltage reaches 4200V peak.
Yanom
Fri Sept 14 2012, 12:47AM
I was looking at this pulsed induction coilgun, where he has to use big, expensive polypropylene capacitors because he needs high energy and nonpolar. So I was wondering what sort of nonpolar capacitor gave the best cost per Joule, and I saw that you could make your own out of aluminium and plastic/wax paper for cheap.
Tony Matt
Fri Sept 14 2012, 02:44AM
Yanom:
Please inform:
Cap AC working voltage, dc peak voltage & capacitance.
Cheers
Yanom
Fri Sept 14 2012, 03:05AM
Tony Matt wrote ...
Yanom:
Please inform:
Cheers
I was looking for something in the tens of kilovolts range. Of course, that would mean building a means of generating HV, probably a C-W multiplier... but that's another story.
I'd like as much capacitance as I can get. How much do you think I could get with two whole rolls of aluminum foil, with wax paper in between?
Ultimately, though, I'm looking at cost per Joule. With aluminum electrolytics, it's about 20cents a joule, but if you want nonpolar stuff like what was used in that pulsed induction coilgun (which I'd like to emulate) it jumps to like $2 USD a joule. So I was looking at the cost-per-joule of homemade stuff.
Dr. ISOTOP
Fri Sept 14 2012, 04:27AM
Yanom wrote ...
Tony Matt wrote ...
Yanom:
Please inform:
Cheers
So the problem isn't just cost-per-joule; reliability is also important.
Without proper vacuum potting, your dielectric is going to degrade real fast at 20KV, leading to many capacitor replacements.
Yanom
Fri Sept 14 2012, 10:38PM
Dr. ISOTOP wrote ...
What's vacuum potting?
Also, how do I calculate the capacitance of a capacitor, given the plate area, dielectric thickness, and dielectric constant?
