  • Guests: 56
mot powered tesla coil cap question
lokeycmos
Thu Sept 06 2012, 12:12AM Print
lokeycmos Registered Member #2553 Joined: Fri Dec 18 2009, 01:36PM
for my second tesla coil i would like to build a MOT powered coil. my first question is, how do i calculate the optimal resonant capacitor if i dont know the exact voltage and current rating of the MOT? when i built my NST coil there was a label with the voltage and current ratings that i could type into TeslaMap(the software i used to calculate my parameters)
Thu Sept 06 2012, 11:16AM
Hi, use 2300Vac, you will most likely need to limit the current on the primary side of the transformer.
PS. One MOT alone is not really enough for a TC. You might want to at least double it and use a DC resonant charging circuit to get 12kV on the caps.
lokeycmos
Sun Sept 23 2012, 12:04AM
to accurately calculate the optimum tank capacitor i need to know the current rating of the MOT. What is the best way to calculate this? what do i use as a load when measureing the current with clamp on ampmeter? or can i just use the short circuit current reading?
