  • Guests: 47
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
cant get feedback with phase lead on UD2
mmt
Tue Sept 04 2012, 06:51PM Print
mmt Registered Member #2333 Joined: Thu Sept 03 2009, 03:04PM
Hello, There's a problem with my UD2. I cant get any useable oscillations at feedback section when i'am using LR phase lead. Only when i remove phase selection jumper (which opens LR), feedback starts working, but there's too much ringing at bridge output so i need to adjust the phase..
i've tried to adjust variable inductor between 0-48uH with no result
the driver i am using is UD2.1
fullbridge cm150DY-12H
gate resistors 5ohm
70kHz secondary
1346784517 2333 FT0 Img 3254
bridge out
1346784517 2333 FT0 Img 3255
bridge out vs nasty noisy current
nixie
Thu Sept 06 2012, 02:12PM
nixie Registered Member #3908 Joined: Tue May 24 2011, 09:40PM
mmt wrote ...
i've tried to adjust variable inductor between 6-43uH with no result
gate resistors 5ohm
70kHz secondary
That result looks familiar.
If you fabricated a board using the 2.1 rev B eagle file, the feedback circuit has a connection problem.
The board does not match the schematic below.
1b Fb
The non-inverting input (pin2) is disconnected from the feedback circuit.
Follow the modification in the image below, making the board match the schematic.
There is one cut marked with a red line, and one jumper marked with black pen.
Ud Board Fix
Hope this helps. It tripped me up for a couple of hours.
Jeff
mmt
Thu Sept 06 2012, 04:16PM
Hi, i've saw there's something wrong with that part, but i fixed it before i made a PCB. so the error must be somewhere else.
but thanks for reply ;)
Kizmo
Fri Sept 07 2012, 05:55AM
Great find nixie! I had same problems with boards made from steves files :)
I managed to solve the problem with conventional troubleshooting (=poking around with multimeter and scope..)
Im in process of going through UD2.1 schematic and parts list and making better component placement drawing. Putting mine together with eagle file and schematic was pain in the ass tongue
