  • Guests: 34
12/25 Kolas (18)
12/26 buxtronix (50)
Stirling engine
Tue Sept 04 2012, 01:47AM Print
Is it possible for a home builder with a lathe to make a stirling refrigeration engine using helium? Or, does this require very precise tools to make and seal the engine?
I've calculated that for helium with a gamma of 1.67 as the compression gas, I only a 1:10 compression to get to 67K
Fri Sept 07 2012, 11:08AM
helium is pretty tiny, if it manages to seep out of the pores in a latex balloon I imagine it would be hard to get a metal on metal seal tight enough but there might be gasket material thats up to the job.
Ash Small
Fri Sept 07 2012, 11:22AM
Nik wrote ...
Helium is used for leak testing of vacuum systems for precisely this reason.
The gas is monatomic, whereas hydrogen is diatomic, so molecules of hydrogen gas are larger than helium molecules (I think this is the correct terminology).
Helium seeps through just about everything, and, I imagine, is very difficult to compress to high pressures..
Fri Sept 07 2012, 04:20PM
I agree with both of you. At minimum this would need a CNC to make the parts. THere is a reason the smallest cryocooler engine is over $10,000.
Fri Sept 07 2012, 04:28PM
If you are looking to just cool things down or make liquid nitrogen there is a guy named Ben Krasnow who you might want to google. He built a liquid nitrogen condenser for ~500$. You can check it out here -> Link2
*edit* Derp, misunderstood the goal of the project
Fri Sept 07 2012, 04:31PM
CNC machining isn't the same thing as accuracy. You can achieve all the accuracy in the world with hand-operated tools if they are high quality and you know what you're doing and have a lot of time to spend.
I imagine helium leakage would be more of a thing that would happen over a long period of time, you would come back the next day and the system would be empty. This wouldn't be a problem for a hobbyist system that could be topped up.
To get enough leakage past the piston to spoil your compression ratio, you'd need orders of magnitude worse machining skills.
You can find cryocoolers on Ebay now and again. The Superfilter from Superconductor Technologies has a tiny one inside. Link2
Ford and Philips worked together on Stirling engines for cars in the 70s. They used very high pressure helium as the working fluid. Link2
Pinky's Brain
Fri Sept 07 2012, 04:37PM
Can't you just compress the NO2 before liquefying it and letting some of the liquid NO2 boil off during decompression? Seems easier than going straight to -200 Celsius.
Marko
Sat Sept 08 2012, 05:33PM
Hey guys,
I actually think that after all a stirling engine may be the cheapest and most straightforward way to obtain LN2 at home.
I definitely wouldn't count on any homemade piston to actually seal helium against the atmosphere; it would be instrumental to make the whole machine sealed and pressurized, including the electric motor (much like it's done with fridge compressors), and electrical feedthroughs would have to be made for power.
The piston in the engine will experience high temperature differences and sealing at low temperatures is difficult as there are not many materials that remain elastic enough, and pretty much any lubricant would freeze.
I think teflon may be the best choice here without requiring any seals - perhaps both the displacer and drive piston could be made out of it, and a feedthrough for displacer shaft made directly through the main piston.
The cylinder would simply be a smaller stainless steel pipe welded onto a larger one which contains the motor and mechanics, and is sealed with sheet metal on the ends.
It would be expected for the gas to leak over time by the piston; a one-way valve on the piston would allow it to return.
While this is certainly a complex mechanical project, I think it's doable for someone with enough time and patience, as well as average metalworking skills.
Marko
