  • Guests: 37
DRSSTC transistor cooling, thermal design
Mon Sept 03 2012, 07:43PM Print
Hi,
when you do the thermal design of a DRSSTC bridge, do you take into account "ripple" of die temperature at the interrupter frequency, or do you just average it out?
Ben Solon
Mon Sept 03 2012, 08:50PM
the thermal impedance between the die and the case, then the case and the heatsink will do the averaging for you. there's no way to keep the die temp from spiking, the best you can do is draw the heat out of it as slow as the junctions will allow.
this is the main problem with pulsing igbt's. if you look at the datasheets, they all say "pulse current *limited by device temperature". if you had a way to draw the heat quickly directly out of the die, then the pulse current could be infinite.
Mon Sept 03 2012, 11:05PM
Actually, transient thermal analysis is done quite a bit, especially when it comes to RF amplifiers (pulsed) and MOSFETs and IGBTs in pulsed applications. Yes, there isn't much you can do thermally to really help with the transient heating of the die (as opposed to the steady state average heating), but what you do get out of those analyses is a range of "safe operating pulse" waveforms that can be run without damaging the die.
Tue Sept 04 2012, 07:04AM
Yes, you need to take the ripple into account to calculate the true peak die temperature. IR datasheets include graphs of transient thermal impedance for various pulse lengths that you can use for this purpose. You calculate the average case temperature, then add the peak pulse power, multiplied by the transient thermal impedance at the burst length you're using.
Uspring
Tue Sept 04 2012, 11:50AM
An interesting feature of the transient thermal impedance curves is that the allowed energy for a short pulse decreases significantly when pulse width is shortened. So it seems, that the energy dissipation in the die is more and more localized for shorter pulses.
Tue Sept 04 2012, 01:49PM
Thanks all for the replies. I did some calculations based on the transient thermal impedance diagram, and the peak die temperature is indeed considerable at lower pulse widths.
