  • Guests: 35
Where To Get High Frequency Current Transformers
currentkills91
Sat Sept 01 2012, 05:55PM Print
Does anybody have any idea where I can get some through hole current transformers good for 1MHz? I have spent all day looking and cannot find anything over 500kHz...
Ash Small
Sun Sept 02 2012, 10:18AM
Wind your own??
currentkills91
Sun Sept 02 2012, 03:16PM
I would, but I would like to have a few laying around for use on different things, and winding several of them seems a bit tedious...
Dr. ISOTOP
Sun Sept 02 2012, 07:29PM
currentkills91 wrote ...
The 500KHz ones will probably work at 1MHz if you don't insist on perfect calibration.
tritium
Mon Sept 10 2012, 03:19PM
tritium Registered Member #2591 Joined: Fri Jan 01 2010, 11:58AM
maybe a Rogowski coil will do the thing?
tritium
Mon Sept 10 2012, 04:20PM
Ben Solon
Mon Sept 10 2012, 10:50PM
as long as you factor in the fact that a rogowski coil displays the change in current, not the current itself. either decode it, or keep that in mind
