  • Guests: 45
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Effect of increasing secondary size on Steve's MicroSSTC?
ahahn
Thu Aug 23 2012, 04:47PM Print
ahahn Registered Member #6075 Joined: Wed Aug 08 2012, 11:48PM
I wasn't able to get the right size PVC for making a secondary with the precise dimensions of Steve Ward's MicroSSTC. Using what I had, I wound ~815 turns (instead of 595) on a slightly smaller diameter pipe. How is this going to change the performance of the coil? I note the design isn't really operating at resonance to begin with. (Presumably it'll mean a fair bit more tweaking when I upgrade it to Class-E, but I want to get the basic version working first.)
ahahn
Thu Aug 23 2012, 07:31PM
I ended up messing with the primary geometry too as a result of the materials I had at hand.
Final dimensions of the secondary:
815 turns, 231mm x 75mm
Primary:
10 turns, 140mm x 30mm
Primary is wound parallel to the secondary, with the top of the primary ending where the secondary begins.
There's a grounded sheet of aluminum about the diameter of the primary about 5cm under the primary, and both driver and secondary have an RF ground in the form of a cold water pipe nearby. (ground connection via an alligator clip and 5cm wide aluminum tape strip in parallel)
I powered it up, and it worked. Discharge into free air was 1-2cm (~3/4"?), I was able to draw a slightly shorter discharge with a piece of aluminum foil on the tip of a plastic bottle. Operation was very nearly silent, a little bit of hissing from the breakout that went away as soon as I drew an arc.
Putting a 10MOhm input multimeter nearby with leads outstretched as a pseudo-dipole suggested a bit of RF output with no arc being drawn (~.2V RMS on the meter, 550kHz). Drawing an arc sent the frequency readout all over the place, as far down as single-digit kilohertz. A broadband diode detector hooked up to a pair of headphones indicated the coil was emitting plenty of hash with no load, but everything went nearly silent as soon as I drew discharge.
The 12V regulator with copper-clad PCB strip as heatsink got a little warm, the HEXFET (on a beefy aluminum one) not at all.
Right, any suggestions on improving it or tuning it to class-E? Right now C3 is the originally-specc'ed 0.001uF, but I've also got 0.0047 and 0.01uF caps that I can swap in.
ahahn
Thu Aug 23 2012, 10:40PM
Followup. I tried calculating the secondary peak voltage and got about 600V, which seems very low given the discharge. What's the proper way to calculate that value?
Here's what I did. Plugging dimensions into JavaTC gives the following values, among other things:
Secondary--
13.226 mH = Lee-Equivalent Energy Inductance
Primary--
21.39 µH = Ldc-Low Frequency Inductance
Vprimary = 24V
Vsec = Vprimary * sqrt( L sec / L primary)
--> 24V * sqrt (.013 / .000013 ) = 24V * sqrt (619) = 24 * 25
= 600V.
(boosting the primary capacitor to .0047uF and telling JavaTC to optimize it ends up giving me a calculated 767V secondary peak voltage; with .01uF on the primary that goes up to a hair under 1120V.)
Uspring
Fri Aug 24 2012, 01:27PM
The equation you used applies only to SGTCs. There is no simple way of calculating the output voltage of a SSTC. It involves the primary and secondary resonant frequencies, coupling, secondary spark load etc.
ahahn
Fri Aug 24 2012, 02:27PM
Is there any documentation you can point me to on how to calculate the output voltage, or at least what's involved?
Uspring
Fri Aug 24 2012, 02:54PM
I not aware of any docs about this. You might want to try a Pspice simulation.
ahahn
Fri Aug 24 2012, 03:15PM
I don't know enough about SPICE to simulate the magnetic field interactions of a Tesla coil. So:
How do primary & secondary resonant frequencies affect output voltage?
...coupling?
...secondary spark load presumably just affects the secondary resonant frequency.
When people talk of Class-E, is that merely driving a primary & secondary with equal resonant frequency at that frequency? Does that change the output voltage, or merely the amount of current available at the output?
