  • Guests: 61
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
SGTC Waveforms and tuning - please comment
rulmismo
Tue Aug 21 2012, 10:12PM Print
rulmismo Registered Member #4187 Joined: Fri Nov 04 2011, 08:08PM
Hi,
I got working recently my first coil, a 480VA SGTC that gives maximun 30cm arcs to pointy targets.
http://youtu.be/G0mHsPRLULU
I don´t know if it is properly tuned but it is the better that I could moving primary connection. Frequencies seem to match quite reasonably javatc resullts.
K is about 0.1 and primary N just about 3,4 turns (lead and MMC stray inductance are a little high).
Spark gap is just 1 gap of copper tube with vacuum cleanear sucker type.
I am not sure if it is usual that just two nothes quenches the arc.
Regards and thanks for your feedback!
]tesla_coil_waveforms.pdf[/file]
Sigurthr
Wed Aug 22 2012, 01:39AM
The coil appears to be firing at a VERY slow rate, which is usually what happens when the spark gap is too wide. Try adjusting the gap closer until you can't hear each individual "click", you should get better results. As it is now the coil is probably ringing down completely between each firing, which limits streamer growth in SGTCs.
rulmismo
Wed Aug 22 2012, 07:54AM
Thanks for the reply.
It is firing every 50ms aprox. see graph,
I will try that, th gap is about 8mm now. I will test in some days and update...
should I get 10ms firing rate to optimise it?
1345622083 4187 FT143656 Firing
Sigurthr
Wed Aug 22 2012, 08:40AM
50mS = 20Hz
I knew it sounded off but I didn't think it was that low!
A normal range of firing rates would be about 60Hz to 300Hz. The "ideal" rate for single static spark gap with a "holy grail" NST/MMC combo falls in the 150-200Hz range. So, aim for 175Hz, which is the coil firing every 5.714mS.
Wed Aug 22 2012, 09:55AM
I agree, you should make your spark gap smaller before you burn out the NST from overvoltage. frown
A static spark gap charged by an AC supply fires in a chaotic pattern, so it is hard to say what the break rate actually is. But you should definitely aim for an average break rate more like 200 than 20. smile
BTW, are these traces from a Picoscope?
rulmismo
Wed Aug 22 2012, 10:40PM
I hope the Terry filter has protected the nst, it wasn´t cheap stuff!
The traces are from a picoscope 3200 with an additional differential probe.
The scope works well, but by experience it is better not use typicial x1 x10 probes if you measure anything>30V. Now I use fixed x10 or differential.
I have no idea of how to take measurements of E field, but following some info about secondary tuning that I found from an old magazine I just used the open leads (10cm apart from each other) in front of the coil. Even without switching on the probe (?) the scope will show the waveforms.
Any of you know where to look for to make a basic E field probe for cheap guys with just an scope? (I guess that some impedance matching to the 1GOhm scope input should be used..).
Regards
