  • Guests: 91
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
1,000,000,000,000 Frames/Second Photography
kimbomba
Tue Aug 21 2012, 12:35PM Print
kimbomba Registered Member #3854 Joined: Fri Apr 29 2011, 03:45AM
This is almost unbelievable Link2
brandon3055
Tue Aug 21 2012, 01:18PM
Haha I was wondering if anyone would post that my robotics teacher showed the class yesterday the main thing I would like to know is how did they make such a short burst of light
Daedronus
Tue Aug 21 2012, 02:59PM
femtosecond ti:sapphire laser
I think they just photograph distinct pulses at different moments in time.
Tue Aug 21 2012, 10:12PM
That is correct. You are not watching one "bullet" of light, but several. The device captures light packets at various times, and then plays it back. Since each packet looks the same this gives the appearance of one packet moving.
Ben Solon
Wed Aug 22 2012, 02:28AM
there was a post not too long ago on the exact same experiment. to repeat what imsmooth said in a slightly different way, they're pulsing light, and taking a snapshot at a time incremental to the previous capture. there's still no possible way to capture continous data this fast.
Uspring
Wed Aug 22 2012, 10:53AM
The real trick is to get picosecond shutter speeds. AFAIK they use streak tubes, i.e. they deflect electrons coming from a photo cathode. These electrons are swept over a position sensitive anode with a rapidly varying electric field much like a high speed CRT.
Probably billions of single shots are needed to produce a video.
Thu Aug 23 2012, 02:49AM
I wonder how long it takes to collect the frames they need to make a video. They have to fire over and over and take each time delayed line of image. It could be anywhere from minutes to days depending on how many pulses it takes and how long it takes to get the data from ram into permanent memory.
