  • Guests: 54
Anyone know what this connector is called?
Alex M
Sun Aug 19 2012, 09:32PM Print
Does anyone know what type of connector this is?
1345411543 3943 FT0 Dsc 2271
Its from some bedroom lights that I am trying to fix, it connects them to their 230-24v AC wall wart. Only problem is that there is a loose/broken wire right at the part where the wire enters the plug moulding.
But if I can find a replacement plug online somewhere then I am going to fix it since these lights were quite expensive, only thing is I do not know the proper name for this type of plug so don't know what to search for.
So if anyone knows the correct name for this type of plug then I would greatly appreciate if you could let me know.
Thanks! cheesey
Ash Small
Mon Aug 20 2012, 12:47AM
Can you include a scale reference in the photo please? It would help a lot. (Ruler would do smile )
Alex M
Mon Aug 20 2012, 12:55AM
Ash Small wrote ...
Yes sure, sorry about. My tape measure seems to have gone walk about so here it is with a 9v battery.
1345423936 3943 FT143554 Dsc 2274
It was slightly longer but I tried to cut away at the plastic to get to the cores (and failed).
plazmatron
Mon Aug 20 2012, 11:25PM
These are non standard cheap Chinese plugs.
The closest I could find to yours were these here:
Scroll down to part number 48-1020
It looks like this:
1020
Alex M
Tue Aug 28 2012, 06:47AM
plazmatron wrote ...
It looks like this:
1020
Thanks for that.
Well I ended up doing a bit of DIY to it as I found some prongs on an old CRT board that fit the output sockets on the wall-wart. I soldered the wires from the lights to them, heatshrinked them and once re-inserted covered them in hot glue for extra protection. Seems to the job.
At-least now my sister is no longer pestering me every 5 minutes with "can you fix my lights?" cheesey
