  • Guests: 42
Russian big DRSSTC pair
zrg
Sat Aug 18 2012, 09:46PM Print
zrg Registered Member #4762 Joined: Sun May 06 2012, 05:59PM
Hi everyone.
This is my biggest and probably most successful project so far, the dual big-sized DRSSTCs, and I bet these are the ugliest (from the view of the electronics layout design) scenic-size Tesla coils you guys have ever seen here :)
The coil pair is known to be the second biggest in Russia (and the second known DRSSTC of that size here at all).
H-bridge: 2x CM300DU-24NFH, 4x EPCOS 400V@6800uF, 2 in series, 2 in parallel, 20uF 800V through-mount EC film caps, per each coil.
Driver: Steve Ward's UD 2.1 rev. b, with UVLO curcuit added (seriously, I have no idea how such a great in other views driver could have no built-in undervoltage lockout), via the OCD triggering.
Interrupter: Steve Ward's MIDI interrupter, adapted to USB->COM usage (frequency changed from default MIDI's to COM port's). Reprogrammed by a friend of mine, much more skilled in microcontrollers.
MMC: 300nF 10kVDC (5-6 kV working voltage with OCD set to 1200-1300A) made from 300x EPCOS B32652 0.1uF 1000VDC each.
Secondary: 25*110 cm.
Topload: 80x20 cm toroid from aluminum ducting.
Secondary frequency ~90 kHz.
Primary has about 4.2 working turns, and inductance of 9.2 uH. The current reaches OCD limit of 1300A in about 6 or 7 periods. Unfortunately I don't have scope shots, forgot to take any. Bridge remains cold (30-36 deg. C maximum) at any working conditions.
Bridge bus capacitor pre-charge circuit is done with a 27 Ohm resistor and a power relay shortening it, triggered by a timer (3 seconds delay).
Never measured total power consumption, but a single coil draws enough to lower the voltage in a wallsocket for 30-40 volts at high BPS, so I won't have a chance to run a paired system simultaneously at my place.
A single coil gives 2 - 2.6 meters spark. With a good supply and OCD tweaking that could be increased to 3+, but that will probably happen with some other project than this.
1345326392 4762 FT0 Dsc 3896
1345326392 4762 FT0 Dsc 3899
1345326392 4762 FT0 Dsc 3904
1345326392 4762 FT0 Dsc 3905
1345326392 4762 FT0 Dsc 3945
1345326392 4762 FT0 Dsc 3959
zrg
Sat Aug 18 2012, 09:50PM
And that's for the sparks.
1345326645 4762 FT143506 Dsc 4068
1345326645 4762 FT143506 Dsc 4072
1345326645 4762 FT143506 Dsc 4073
1345326645 4762 FT143506 Dsc 3940
1345326645 4762 FT143506 Dsc 3922
1345326645 4762 FT143506 Dsc 4061
Sun Aug 19 2012, 12:23AM
Fabulous !
almost the first thought that popped into my head :
this is like a 'woofer' to match American/UK 'mid-high range' musical TC.
GREAT !
nixie
Sun Aug 19 2012, 04:37PM
nixie Registered Member #3908 Joined: Tue May 24 2011, 09:40PM
zrg wrote ...
Hi everyone.
Please elaborate on the UVLO modification you made to the UD2.1 driver smile
I can't determine by the image whether you are using a zener shunt detect, or an LVR IC in a TO-92 package to clamp the signal.
A little hand scrawled schematic would be great!
I would like to implement this feature as well. I thought about this issue when stuffing the board, and you have already done it.
Thanks, Jeff
