  • Guests: 65
kywalda (63)
12/19 kywalda (63)
12/20 plazmatron (48)
12/20 rm203tech (17)
zvs deadly?
Microwatt
Thu Aug 16 2012, 06:53PM Print
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
has anybody ever gotten electrocuted from a zvs flyback? no capacitor no conditioning. I know some of you have but are afraid to speak up.
Ben Solon
Thu Aug 16 2012, 06:58PM
if anyone was electrocuted, they wouldn't be able to tell you. you could check for user inactivity though.
Harry
Thu Aug 16 2012, 09:49PM
Harry Registered Member #4081 Joined: Wed Aug 31 2011, 06:40PM
IIRC Platinum was, ZVS flybacks aren't deadly. Possibly under ideal conditions they are.
I have a microwave inverter transformer, THAT is deadly with ZVS, a few hundred mA at a couple of kV
Alex M
Thu Aug 16 2012, 11:41PM
Electrocuted implies that you did not survive having current pass through you.
Electric shock is the one you are looking for, which means you lived to tell the tale.
I think a regular LOPT driven with a royer "ZVS" driver can certainly kill if the current travels in the right places. If you were using a homemade secondary which usually only puts out a few kV and a much higher current then the risk of electrocution if you touched it would probably be higher.
Sorry if my reply is hard to read but wink
Harry
Thu Aug 16 2012, 11:54PM
I guess it depends massively on all kinds of factors, skin moisture content, input voltage, flyback model, amount of electrocution time etc . . .
I've been shocked once by accidently touching the HT output with a screwdriver, it must have broken down the insulation on the handle. Gave me a bit of a jolt but licking a fresh 9V battery is worse.
brandon3055
Fri Aug 17 2012, 01:07AM
I don't think skin moisture makes much difference when you get into the kv range but I think it definitely could have an effect when getting a shock from mains or similar voltages and speaking of getting shocks from barrerys I learnt the hard way that its not a good idea to remove the insulation from wires with your teeth if the other end is attached to a 12v battery OUCH!
Ben Solon
Fri Aug 17 2012, 01:10AM
Destroyer of mosfets wrote ...
or stepper motor drivers. i have that bad habit too...
Paul_J.
Fri Aug 17 2012, 03:34AM
Paul_J. Registered Member #5436 Joined: Sun Jun 24 2012, 01:44AM
ben123324 wrote ...
Oh, that's just not very nice.
Ben Solon
Fri Aug 17 2012, 04:39AM
Paul_J. wrote ...
ben123324 wrote ...
Sorry, I've been told I have an extremely dry sense of humor. Nothing mean intended smile
ZakWolf
Fri Aug 17 2012, 05:07AM
I have been shocked by a zvs from arm to arm across the chest, it was powered by an 18v battery.
