  • Guests: 56
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
noisy GDT
Unleashed
Wed Aug 15 2012, 11:42PM Print
Unleashed Registered Member #5171 Joined: Tue Jun 05 2012, 11:32AM
Hello everyone.
Just as title, i turn on my SSTC driver, with no input from the feedback antenna,with a led connected to the GDT... and it's noisy like bzzzzz....
even when i turn it on when attached to the tc, it's noisy.
The thing is, the led is turning on and off.. but this noise from the GDT is normal?
Thu Aug 16 2012, 08:27AM
Good, no. Normal, yes. smile The simple feedback driver circuit that is so popular with SSTC builders has no frequency discrimination. I wouldn't be surprised if it were picking up 50Hz hum from the line voltage.
If you're using an interrupter, the GDT will also "bzzz" at the interrupter frequency in the absence of any RF signal from the coil.
In normal use, the signal from the coil should dominate and everything should be OK.
Unleashed
Thu Aug 16 2012, 11:16AM
kerver
Mon Aug 20 2012, 04:12PM
kerver Registered Member #522 Joined: Thu Feb 15 2007, 01:04AM
Maybe a 10k ohm and 1nf cap give you a better picture.
Greetz from the Netherlands.
