  • Guests: 63
IAmSpock (18)
01/30 Ian (37)
01/30 Lucas (40)
01/31 Mathias (42)
Thyristors
Wed Aug 15 2012, 09:16AM Print
Hello,
ive found this cheap thyristor: Link2
im thinking of using 4 to make a controller simler to Goodchild's one, the think im haveing some trouble with, is that i cant find a datasheet for these thyristors anywhere.... is that normal for ebay goods from china? mistrust
Jrz126
Wed Aug 15 2012, 11:25AM
Found this
If you add "filetype:pdf" to your google search, it'll only return PDF results. makes it easier to eliminate the thousands of component supplier pages.
Cant comment on the quality.
Forty
Wed Aug 15 2012, 03:23PM
yea i've looked at those ones before. doesn't the peak current seem a bit low at <2x the nominal?
Wed Aug 15 2012, 05:54PM
is that important for non coilgun/ pulse ect applications
Forty
Wed Aug 15 2012, 06:00PM
no. i just question how well they're made because every other thyristor i've seen has a much larger pulse rating. i thought it was sort of an intrinsic quality of scr's in general.
Wed Aug 15 2012, 08:44PM
hmm, thats a good point, could i theoreticly substitute a Variac with a bridge of thyristors & controllers?
Ben Solon
Wed Aug 15 2012, 10:37PM
the ones at ctr surplus are affordable, and they're all rated for huge currents
