  • Guests: 73
Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
02/05 teslaguy (36)
Need Help Triggering SCR
Yanom
Sun Aug 12 2012, 09:34PM Print
Yanom Registered Member #4659 Joined: Sun Apr 29 2012, 06:14PM
So I'm building a coilgun and I've got an SCR that i'm going to use to discharge a 550uF 600v capacitor through the coil. But I'm having trouble triggering it. Connecting the positive terminal of the cap to the gate of the SCR is infeasible, because it will probably blow out the SCR (max gate power 10W) unless I use a resistor of such high value that it reduces the gate current below the required 50mA or so. So I must use a battery circuit. I built this circuit, but there is an arc across the fire switch as I close it. Does anyone know why? How would you reccomend triggering the SCR?
1344807272 4659 FT0 Coilgunscr
2Spoons
Sun Aug 12 2012, 10:37PM
connect battery negative directly to SCR anode. In your current circuit as soon as the SCR triggers the anode voltage rises to within a few voltage of cathode - well above the 9V trigger. This is due to the inductor on the anode side.
Yanom
Sun Aug 12 2012, 11:54PM
2Spoons wrote ...
are you sure you dont mean cathode side? inductor is on cathode side. also its supposed to be 30mH not 30H
m4ge123
Mon Aug 13 2012, 06:40AM
m4ge123 Registered Member #4118 Joined: Mon Oct 03 2011, 04:50PM
Yanom
Mon Aug 13 2012, 03:35PM
so, I should put the coil before the SCR in the circuit? Will do. Also, it appears that I hook up the neg. terminal of the 9v battery to the (cathode, emitter, output, whateverYouCallIt) terminal of the SCR.
What if I had to trigger multiple SCR's on different circuits (circuits I don't want touching each other) with the throw of a single switch? How would I make that work?
Mon Aug 13 2012, 04:12PM
You've got it ass-backwards- the trigger voltage should be applied between gate and cathode of the SCR. (Edit: I see you realised this in your above post. tongue)
To trigger multiple isolated SCRs, pulse transformers are often used. Suitable transformers are available for a few bucks.
Yanom
Mon Aug 13 2012, 08:26PM
Steve Conner wrote ...
How would I wire that up? and what excactly is a pulse transformer?
By the way, why does this below method not work?
1344889568 4659 FT143185 Scrbatteryresistor
2Spoons
Mon Aug 13 2012, 10:42PM
Sorry, not thinking straight - got anode cathode reversed.
Re that circuit: "current flows in loops". That simple statement is absolutely fundamental to all electronic design.
Now ask yourself how could current flow into the gate when there is no return path back to the battery?
Yanom
Mon Aug 13 2012, 11:11PM
2Spoons wrote ...
...I'm an idiot. :/
I guess this means that an SCR trigger circuit can never be isolated from the power flowing through the SCR. Which is bad, because I may need to trigger many SCR's at different voltages with the throw of a single switch. The fact that there is a current path from gate to cathode also makes this problematic.
I'm thinking about trying to build what's essentially a marx generator, but at lowish voltages (100-400v) with SCRs instead of spark gaps.
2Spoons
Tue Aug 14 2012, 01:25AM
Steve Conner has already told you the answer to this : pulse transformers. This will provide the isolation you are looking for. Opto couplers are another possiblity.
