  • Guests: 71
Bauerb2 (36)
02/03 Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
Formula for capacitor ESR estimate?
Yanom
Sat Aug 11 2012, 03:37PM Print
Yanom Registered Member #4659 Joined: Sun Apr 29 2012, 06:14PM
I have a few caps I'm using for a small coilgun and I wanted to know their ESR. I don't have a capacitance/ESR meter, so is there a formula that lets me find the ESR based on voltage, capacitance, etc.? These are standard, polar, electrolytic capacitors, 350V 1100uF in this case.
I understand that ESR can vary based on frequency, but this is a DC circuit where I charge them up then discharge them through the coil.
Ben Solon
Sat Aug 11 2012, 03:53PM
i've never done it myself, but if you have a storage scope you could hook it up to a power source, then measure the time it takes to charge up to a time constant. then just calculate the resistance.
Sat Aug 11 2012, 04:46PM
You should be able to get that information from the manufacturer, especially if its an electrolytic. Just look up part number on their website or if they don't have it available, just make a phone call to them and talk to their tech support. Much easier then trying to rig up something to calculate ESR. They should be able to give you both ESR and ESL.
