  • Guests: 35
Will T (16)
william L (29)
Tipiment (62)
12/17 Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
SLR HALF BRIDGE WAVEFORMS
bwsparxz
Tue Aug 07 2012, 01:06AM Print
bwsparxz Registered Member #1928 Joined: Mon Jan 12 2009, 01:51PM
What typical GDT primary and CT half bridge out waveform should I be looking to obtain to prevent damage to IGBTs? 50% duty cycle ? What is normal GDT frequency for a SLR topology? Yes, I'm destroying IGBTs so I must have something wrong and after searching , did not find a clear answer to these questions. Any advice appreciated.
Dr. ISOTOP
Tue Aug 07 2012, 01:13AM
GDT primary should be a 50% duty cycle AC square wave.
Primary current should look like this: Link2
The current waveform should be extremely clean; any ringing or high-frequency components, and something is wrong.
Run a frequency high enough to not saturate your core and draw reasonably low reactive current, but low enough so that the switching delays of the IGBT's don't prevent good ZCS.
