  • Guests: 73
02/03 Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
Boost charging SLAs from lithium bank?
Mon Aug 06 2012, 06:58PM Print
Hi all.
Seems that it is feasible to use 3 12V 7Ah in place of heavy 12V 15Ah on an electric bike.
The problem is that I also have a pile of perfectly good but unmatched LiPos totalling 40Ah at 4V or 20Ah at 7.2V
Would it be feasible to make a voltage converter (probably 34063/MOSFET based) that converts this into charge voltage for the lead acid bank?
Was thinking around 2A charge current so when the motor isn't being used the batteries are always charging.
-A
brandon3055
Mon Aug 06 2012, 10:32PM
As you probably already know you will also need a protection circuit to stop the lupo's cell voltage getting to low.
Maby zvs with a diy transformer would work if you can get it to run at such a low voltage
Dr. ISOTOP
Tue Aug 07 2012, 01:22AM
You can boost 7.2V to 14.4V if you use a boost converter and a logic level FET.
Electra
Tue Aug 07 2012, 11:31PM
Not sure it’s a good idea to put unmatched cells in series because of the cell balancing problem.
I ain't a fan of lipos for experiential stuff cos they are so fussy and it’s too easy to kill them, though having said that I realise they would have significant advantages for electric vehicles and the like.
Using a battery to charge a battery, may be only be around about 75% efficient for the lead acid type as you have to charge at a higher voltage than you got out, and generally put more amp hours back in than you took out to balance it up, as some is lost as heat e.c.t
The push pull converter tends to be quite popular at low input voltages,
But the question is how much effort and time is this, compared to a new battery pack of the right voltage that you could run the motor off directly, or with a change over switch if you kept the existing battery as a reserve.
Wed Aug 08 2012, 07:45AM
Yeah, a changeover switch is a good idea.
The big problem is that the cells have to be both impedance and voltage matched, any suggestions?
-A
