  • Guests: 55
my new DRSSTC
Mon Aug 06 2012, 12:40PM Print
ok, im working on my SSTC at the moment,
but for my next project im thinking of making a DRSSTC, which IGBTs should i go with:
-4x IXGN60N60
or
-2x CM300DY-24H
going to be a medium sized DRSSTC
thanks
Thomas~~
Bennem
Mon Aug 06 2012, 01:19PM
Bennem Registered Member #154 Joined: Sun Feb 12 2006, 04:28PM
cm300 is a bit over kill for a medium sized DRSSTC.......60N60 will be ok...imho
btw.....you need to use a phase compensation driver especially with the cm300 bricks
more so than the 60N60's
Mon Aug 06 2012, 03:06PM
If you look at my DRSSTC I, it uses 60N60 and is what I would call a medium coil, maybe rangeing into a lesser large :)
1.5 meter sparks but not enough for that size coil and I run them at 500A which is their upper limit. I got CM300s to upgrade it with when I get time.
I want to upgrade since there is very little headroom left with the 60N60, running longer ontimes and very high BPS is just not a desirable road to go down.
Mon Aug 06 2012, 03:47PM
i was thinking going with CM300 because i will run it less then its rated for, giving headroom, because i dun wanna blow this stuff D:
Dr. ISOTOP
Tue Aug 07 2012, 01:19AM
__=|(:3)-|--{__ wrote ...
CM300's are also much, much slower than 60N60's, so you need to take that into account.
Tue Aug 07 2012, 05:04AM
Dr. ISOTOP wrote ...
I will use the CM300s in a 70kHz coil and have used the 60N60 in 300kHz coils.
Killa-X
Tue Aug 07 2012, 06:10AM
Yup...Will say im running a fullbridge of CM300DY-12NF, Ive been told to keep em around 100khz. I run them at 48.9khz. They are rather slow, as others have stated. Just being another witness :D
Tue Aug 07 2012, 07:27AM
Hmm, if i went with these, how much more money would a rig like this lightly cost? im planning to get the IGBTs from EVR Used/Surplus because they are only $99 each
Im thinking of following somthing like Goodchilds design for the DRSSTC, i really want to know, where can i get a board made of that quality for my driver? will steves latest driver work for this coil, im relitivly unfamilier with DRSSTCs, how much tuning will i haveto do likely, is there lots of things to modify? or is more or less plug and play once youve tested each part works?
Thomas~~
Tue Aug 07 2012, 06:37PM
Thomas~~
My first DRSSTC cost me something like 400$ maybe, plus minus...
But if you are willing to pay 99$ for each IGBT if will get a lot more expensive, I found surplus CM300s in Europe at about half that price. Link2
I have always used Wards drivers and got nothing but good to say, Goodchilds is a deviation of that and both (can) incorporate Finn Hammers prediktor.
DRSSTCs are a huge step up in complexity from SSTCs, you will have to know what you are doing or learn it doing building and testing. Failure modes and faults is about 10 fold.
Nothing is really plug and play about Tesla coils as a whole and DRSSTCs is rather picky on tuning point, its within a few centimeters on the primary coil to find the sweet spot.
Go for the challenge, learn something new, build a magnificent Tesla coil and prepare to spend some hours, tears and cash :)
PS. do NOT doublepost.
Tue Aug 07 2012, 07:38PM
Yes, you can purchase surplus bricks from a variety of sources, however, you are taking a gamble whether or not they work as most surplus supplies do not test their IGBT bricks other than a ohmmeter test. The surplus bricks we sell are all tested under load with both DC and pulsed waveforms to ensure they meet the specifications indicated within the manufacturers datasheet.
But that said, many have had great success with their coils going through the standard surplus market. With us, you are merely paying more not for the device, but for an extra level of screening.
