  • Guests: 44
igbt speed
1 2 3 4
zzz_julian_zzz
Mon Aug 06 2012, 11:11AM Print
hi All,
Wanted to ask what would be the highest frequency a CM300DY-24H can handle??
Cause I have a 200kHz drsstc, S.ward's UD1.3 driven, (no phase lead comp)..
Planned to input power 500Watts (325VDC).
According to D.Sheet,
it has
td(on) = 550ns
tr = 180ns
td(off) = 600ns
tf = 350ns
Since my coil is 200khz, the time per cycle is 0.005sec
I have totaled all the above time and reached about 1680nsec..
*in milliseconds.. 5ms per cycle and switching is 0.00168ms
I am thinking that all the delays etc are completely acceptable by the speed requirements,
Any comments about this will be highly appreciated.. THanks!
Mon Aug 06 2012, 12:03PM
your switching cycle is 5us, not 5ms, and switching speed is 1.7ms... this will work very bad, maybe not even at all (IGBT death), especially with no delay compensation.
zzz_julian_zzz
Mon Aug 06 2012, 12:28PM
how did you come up of that conclusion?? is there a computation for this? I mean what is the relation formula or rule of thumb here? It will be a great help if you can show it, thanks.
Also, i don't know how you came up with 1.7ms
Mon Aug 06 2012, 02:50PM
Switching time at 200kHz is 5uS
The IGBT can turn on and off in 1.68uS
Rule of thumb... Best practise... I got no idea, but would assume that a 200% rule ain't too bad to go by. Like if you want to look at a 25MHz signal, use a 50MHz scope. If you want to run a coil at 200kHz, use a IGBT suitable for atleast 400kHz.
This is just guess work, careful study of each devices datasheet will tell you much more about losses vs. frequency etc.
zzz_julian_zzz
Mon Aug 06 2012, 03:16PM
5us will mean 2.5us per half cycle, if there is 1.68 needed for 1 square cycle, it is still in the required speed, although not in the region of 50% margin,. hmmm.. not to mention the delay introduced by the driver itself could add more delay. The losses you are telling is the heat made by the switch isn't it? how do we look for that loss? Thanks..
BTW, any updates on your DRSSTC 3?
Ben Solon
Mon Aug 06 2012, 03:41PM
look at it this way- if the igbt spends 1.7us turning on, then another 1.7us turning off, then its spending 60% of its time in the linear region where losses are huge. the rule of thumb i go by is: Fmax=1/((Ton+Toff+switching delays)*10)
Mon Aug 06 2012, 05:26PM
Sorry I meant to write 1.7us not ms.
zzz_julian_zzz
Mon Aug 06 2012, 10:37PM
with the turning ON delay, it only requires 0.73us and not the whole 1.7us. okay.. so i think I'll try to find another IGBT =) .. thanks for the info guys!
btw, what brick can you recommend for my coil as such? 200khz
Mon Aug 06 2012, 11:36PM
The IGBT needs to turn ON and OFF in 1 cycle so you must add all times together.
Dr. ISOTOP
Tue Aug 07 2012, 01:17AM
The delays are literally propagation delays; time from when the gate voltage hits zero to the time when the collector voltage starts rising. In hard-switched applications, they don't contribute towards losses. In a soft-switched circuit such as a DRSSTC, they contribute towards losses by causing the switching to deviate from ZCS, but the IGBT is not operating linearly during these delays.
