  • Guests: 47
4CX250B VTTC can make 3 METER SPARK?Is this possible?
hsieh
Sat Aug 04 2012, 03:47PM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
Today I show the photos of my 811A VTTC to several people.One of them recognize that it is a VTTC and told me that he once build a VTTC using 4CX250B, it make 3 METER SPARK and the plate voltage he use is 1000 Volt.IS THIS POSSIBLE?
He seems to know a lot about vacuum tubes and he said he is a high power RF engineer.I ask him for the schematic and he said it was lost because he build it many years ago.
I didn't find much information about this tube being used in VTTC.But I know that other tubes with similar plate dissipation rating cannot make 3 meter spark.
Sat Aug 04 2012, 04:26PM
It is not possible.
hsieh
Sat Aug 04 2012, 04:33PM
So What kind of performance can I expect if I build a VTTC using 4CX250B?
Sat Aug 04 2012, 05:30PM
I think the heater of this tube is able to provide ~0.5-1 A of pulsed cathode current, at 2 kV on the plate this is something aroud 2 kW of peak input. Depending on frequency (and many other factors) you might be able to get a ~30cm (12") long spark in pulse, but more likely not even this.
Sat Aug 04 2012, 09:34PM
Maybe he meant to say 4CW30,000? :P
cbfull
Mon Aug 06 2012, 02:12PM
I think he probably meant 4CX2500B. That other tube is only rated for 250 Watts.
Sounds very suspicious. How well do you know this guy? His story is totally questionable.
