  • Guests: 51
How to display TC's output on a scope ?
Tue Jul 31 2012, 06:19PM Print
Hi all,
I recently got a scope and I have no clue how to display/measure a TC output...
I'm looking for something simple (no costly specialized probe). I want to display this small VTTC output.
My first idea is to build a very simple 1:1000 (adjustable up to 1:∞) capacitively coupled "probe", see below schematic.
I would start with the variable resistor (1k) cursor very close to ground and the probe at 2 meters from the coil, then slowly move the probe closer to the coil until I get a good display, then adjust the variable resistor for proper voltage.
Would this work ?
Any better suggestion is welcomed smile (and I guess there are many^^)
Imag1010
Tue Jul 31 2012, 07:17PM
that probe is in effect a series capacitance (from TC secondary to probe)
with resistance to gnd,
so the 'scope would display the differential of the TC voltage.
You need a capacitive divider.
e.g guess 0.1 pF TC-to-probe,
add 1nF capacitance to ground = 10,000:1 probe.
etc.
Tue Jul 31 2012, 07:33PM
Terry Fritz created a novel way to indirectly measure the voltage and current in a Tesla coil using a planar antenna.
Read about his paper here:
Tue Jul 31 2012, 07:40PM
Sulaiman is right, the input impedance of the scope is capacitive at TC frequencies, so just holding the scope probe near the TC will create a capacitive divider. I've used this method often.
Thu Aug 02 2012, 10:35PM
The Terry Fritz probe looks really interesting ! I'm gonna build it as soon as I get some missing parts.
But I noticed something wrong in Terry's calculations : he used "pi R^2" to calculate the surface area of a sphere, when it is "4pi R^2". We have to take this into account when calculating the probe to coil distance that gives accurate current measurements.
I built something quick and dirty (C=10nF, R=68, 75Ω cable) :
Imag1211Spacer11Imag1113
I didn't expect to accurately measure voltage or current, but just to display waveforms properly, and it did well !
Imag1213Spacer11Imag1215
Measured resonnant frequency is 1.948MHz (very close to the 1.953MHz initally calculated with TeslaMap !)
20120510
Thanks Sulaiman, Dan and Steve smile
