  • Guests: 37
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Can I Improve It?
currentkills91
Sun Jul 22 2012, 08:04AM Print
Trying to find an easy way to turn a sine wave into a square wave, and this is what I have so far using an op-amp and an inverter and a couple extra parts:
1342943575 3831 FT0 Square Wave Generator
Is there any way I could make a nicer looking square wave? V1 is a 1kHz sine wave at 0.3Vpp if it's needed.
Sigurthr
Sun Jul 22 2012, 12:50PM
I am VERY much a noob at the signal processing side of EE, but doesn't a simple Schmitt Trigger turn a sine wave in to a square wave?
Sun Jul 22 2012, 03:41PM
Just a clipping or comparator circuit will do it.
genious 7
Sun Jul 22 2012, 05:05PM
genious 7 Registered Member #2887 Joined: Sat May 29 2010, 11:10PM
Yep, a Schmitt trigger.
Or an Opamp with positive feedback (which adds hysterirsis just as a Schmitt trigger)
Ben Solon
Sun Jul 22 2012, 09:26PM
Is it a true -v to +v sine? Because a schmitt triggered gate typically doesn't have it's levels set to be symetrical across 0v. That might not matter to you however.
currentkills91
Sun Jul 22 2012, 09:43PM
Well it would be an audio source coming from my iPod, so I am not 100% sure, however in the real circuit the output would swing from +5V to 0V, not the ridiculous 330Vpp I get with LTspice x.x
