  • Guests: 42
Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
02/05 teslaguy (36)
programs for simulating flyback performance
Microwatt
Tue Jul 17 2012, 11:45PM Print
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
I want to design a flyback transformer driven by half bridge circuit. it will run in flyback mode. what program would be suitable for this?
Daedronus
Wed Jul 18 2012, 09:18AM
A half bridge implies a push-pull drive of the primary. To operate a transformer in flyback mode you just pull it (to ground) then you let it free wheel or flyback.
A push-pull drive will apply a square wave to the primary, in flyback you apply pulses.
Mattski
Thu Jul 19 2012, 03:39PM
LTspice is a good free electronics simulator intended specifically for power electronics: Link2
As with all simulators the accuracy is dependent on knowing what you're doing with the circuit and having accurate models. Modeling precise behavior when there is an arc in the system will take some work, but you can get the idealized behavior with a simple resistive or even RLC load pretty easily.
