  • Guests: 72
RoV IW3IPD (63)
01/12 RoV IW3IPD (63)
Separate Supplies For ZVS Driver
Paul_J.
Tue Jul 17 2012, 04:01AM Print
Paul_J. Registered Member #5436 Joined: Sun Jun 24 2012, 01:44AM
Hello,
I have a multi-kilowatt ZVS Driver fed using a 50 volt supply. Is it preferred to power the gates using a lower voltage supply? If so, what would happen if the Power Supply was unfiltered and the gates were. Would this lead to improper switching? If so, is it needed to supply filtered DC to the driver?
Thank you,
Paul
Hypothetical situation- What if there were 2 different transformers with 2 different bridge rectifiers. Would the resulting current look any different other than in scale?
Tue Jul 17 2012, 07:57AM
Powering the gates separately will reduce wastage of power in the gate pull-up resistors. That's the only benefit. You may feel that two bigass resistors is an acceptable trade-off against the extra hassle of an auxiliary power supply.
m4ge123
Tue Jul 17 2012, 12:06PM
m4ge123 Registered Member #4118 Joined: Mon Oct 03 2011, 04:50PM
It should be fine if the main supply is unfiltered, because the current will get smoothed by the input inductor.
Paul_J.
Tue Jul 17 2012, 03:24PM
I've just thought about what I wrote late last night, and realized that it makes fairly little sense.
Paul_J.
Tue Jul 17 2012, 04:56PM
Jinkela
Wed Jul 18 2012, 02:22AM
Jinkela Registered Member #5788 Joined: Tue Jul 17 2012, 11:25PM
What MOSFET did you use?
I reliaze that IRFP260 may be not the best MOS for ZVS
I did several experiments about zvs
Under 12 volts,IRF3205 is a good choice, for 200W output
IRFP3206 is another awesome MOSFET,it can output about 400W(a challenge for zvs working under 12V power supply)
