  • Guests: 41
01/12 RoV IW3IPD (63)
pcb layouts
Microwatt
Tue Jul 17 2012, 02:28AM Print
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
Hi guys im back do you know who has a pcb layout for a halfbridge driver board? I want to hopefully find one that uses t0247 mosfets and the driver is a dip8. I have a big fly back transformer I want to drive and I want a neat and clean apparatus. If you know of any share sites of have any yourself it would be greatly appreciated.
Tue Jul 17 2012, 02:51AM
well mostly i see people make and etch thier own, but eastern voltage research has some boards already made.
Link2 then again it looks like most peeps are moving to the sot- type mini bricks.
you might have to look on google images.
Ben Solon
Tue Jul 17 2012, 10:02PM
Plenty of people make them, but nobody uses pcb files from other people. The some of the only tc drivers found are Steve Ward's which contributes to the popularity of his drivers, As well as the simplicity and absolute functionality. But if you want a board for a halfbridge of to247's then it would be easiest just to make one. I use eagle for embedded, logic, and drivers because of their netlist capabilities. For power traces I use express pcb. Whenever I do a bridge in eagle it feels like i'm crudely throwing down polygons. It's just a simple inverter, so you should have no trouble as long as you keep layers and power flow in mind.
