  • Guests: 87
RoV IW3IPD (63)
01/12 RoV IW3IPD (63)
Prototype homemade heavy-duty mechanical switch - how much power do you think this could handle?
radiotech
Fri Jul 13 2012, 06:03AM
What is used in metal clad switch gear is a powerful spring and a trip
mechanism. There is a motor which re-tensions the spring once the switch
has been closed.
Those switches could break your arm if you tripped the close with hands
on the contacts. (where they would be during maintenance).
One mechanism you could investigate for home use is a stapling gun.
Figure a way to get the hammer plate to close your contact. These guns
can drive a 5/8 " brad or staple.
1342159396 2463 FT141652 Staple Gun
Fri Jul 13 2012, 03:06PM
That switch will work fine for your application, with only ~20j in your capacitor even a beefy pushbutton switch or contactor would work fine. As others have said, the rubber band around the outside is a little suspect, and you will take a bit of a hit from the steel rods as opposed to copper/aluminum, but I doubt that you will notice much of a difference in your application.
Dri0m
Sat Jul 14 2012, 09:27AM
Dri0m Registered Member #4497 Joined: Thu Apr 19 2012, 12:53PM
Yanom wrote ...
Forty wrote ...
What's the switch for?
coilgun - 250V, with 680uF capacitance, for now.
ehm, LOL
I'm using for my mini coilgun 300V 860uF normal button switch rated for 250V 1A, this one
(and it works)
Newton Brawn
Sun Jul 15 2012, 03:52PM
Hi !
Why do not use a mouse trap ??
Mon Jul 16 2012, 12:26AM
How about something like this. This could give you some ideas. This is a simple high voltage switch by either Reynolds High Voltage or Ross Engineering. Just two contacts and a solenoid which closes the contacts.
1342398361 15 FT141652 Switch
Tetris
Mon Jul 16 2012, 03:39AM
put more and more current through it, and when it finally acts weird, stop. :P
