  • Guests: 37
X3 Eurocopter
Ash Small
Tue Jul 10 2012, 02:17PM Print
Some of the 'copter builders here may find this interesting, if you've not come accross it before:
Tue Jul 10 2012, 02:47PM
so what about retreating blade stall or advancing blade compression? does taking upward force off the rotor disc, and putting it on the wings/forward props reduce the rotor disc aerodynamic problems above 300mph?
Ash Small
Tue Jul 10 2012, 05:17PM
Patrick wrote ...
If I understand your question (and I know very little about 'copter design), I assume the the lift rotor is a lot smaller in diameter , with a greater blade section, than a conventional 'copter, as the lift rotor only has to privide sufficient lift for VTOL, and doesn't also privide thrust.
It also seems to make sense to use the stabilizer rotor(s) (normally at the rear) to also privide thrust, as this power is usually wasted. (hope that makes sense)
