  • Guests: 37
Plate Modulated Tesla Coil (VTTC)
Dr Hankenstein
Mon Jul 09 2012, 03:41AM Print
Dr Hankenstein Registered Member #1642 Joined: Sun Aug 17 2008, 11:36PM
Thought you guys might get a kick out of this; It's a high level (plate modulated) VTTC powered by a pair of 304tl's @ Link2 Jim @ Link2 has done a fabulous job constructing the web page which now includes Schematics and Wiring Diagrams of the actual 304TL modulator! The output blows the doors off of "standard" MOSFET designs, which are normally FM modulated. Although the parts I used may be somewhat hard to find these days, I don't see any reason one can't use a car stereo bass amplifier to do the same thing using MOSFET design and a large filament transformer (6.3 volts or 12.6 volt to 120 volts AC) to do the same thing. I know of someone who has just done this, and his results are incredible. "Talk Power" is where it's at using plate (or buss) modulation. Simple rules are that the modulator needs to have about 60% of the total power input to the RF deck; so for a 500 watt tesla coil, you would need about 300 watts of audio. Peak to Peak envelope power causes the sparks to really "jump" on hard hitting audio; truly fascinating.
Regards,
Hank
"Where real men still use Iron; and lots of it!"
2Spoons
Mon Jul 09 2012, 05:02AM
Very cool - but I can't find an explanation of how the modulator is connected to the TC.
RateReducer
Mon Jul 09 2012, 05:10AM
RateReducer Registered Member #4603 Joined: Wed Apr 25 2012, 07:33PM
Thats a nice setup.
60% of the RF power for audio just to modulate a grid!? amazed
That would explain the low audio output of my coils...
I will change that...
Mon Jul 09 2012, 05:14AM
Really impressive !
Thanks for the post smile
Dr Hankenstein
Mon Jul 09 2012, 05:24AM
FYI: It's PLATE MODULATION, not grid. The modulator xfmr goes between the B+ source and the plate of the coil...relatively simple. Same principle as the "CQW" stuff, you're varying the input to the plate with audio from a series connected xfmr.
Hank
RateReducer
Mon Jul 09 2012, 05:32AM
Ahh okay. Sorry. That explains the high power of the modulator...
"THIS is the modulation transformer, professionally rewound on a 2.2 kVA core by the original builder"
I was wondering what that thing costs amazed
But why plate modulation?
Whats the advantage towards grid modulation?
Regards
Dr Hankenstein
Mon Jul 09 2012, 05:58AM
The Peak Envelope Power (PEP) available from plate modulation is 4X the nominal input power compared to grid modulation, I think that's why the flames "jump" considerably higher than normal FM or grid modulated coils.
Hank
2Spoons
Mon Jul 09 2012, 06:37AM
Thanks for the clarification on connection. Makes perfect sense. No wonder the modulation tranny is so huge.
Mon Jul 09 2012, 08:35AM
Well it is really cool, no doubt about it... but I think that screen or suppresor modulation (with a suitable tube) would require about 1/3 of the components and total weight cheesey
RateReducer
Mon Jul 09 2012, 09:34AM
And less than 1/10 of the costs ^^
