  • Guests: 62
PID + servo PWM... how to implement !?
Mon Jul 09 2012, 03:12AM Print
hey everybody my brain is not able to wrap around this problem. i need to go from angles and velocities to RC servo PWMs, so am i not understanding the implemantation of a pid?
is it possible for a pid to not be aware of the pwm, and only the result? ordoes the output need to be "normalized" somehow to be complatiable with the rc pwm?
im using this C example for my code: Link2
AndrewM
Mon Jul 09 2012, 03:13AM
I'll need a video before I can be of any assistance.
Mon Jul 09 2012, 03:17AM
AndrewM wrote ...
Ha!! i knew it.
Mattski
Mon Jul 09 2012, 06:49AM
What variable are you trying to control? My understanding was that servomotors are already controlling their shaft position based on the input pulse time so there's no need for a PID loop. If you're trying to control velocity I'm not sure you can with a servomotor because you don't have feedback from the shaft sensor.
Mon Jul 09 2012, 06:52AM
Mattski wrote ...
well its my tilt rotor fans and angular position im trying to control with a pid + complementary filter.
Dr. Slack
Mon Jul 09 2012, 07:19AM
You probably don;t need PID to control the fan angle, just set the PWM to to required position and let the servo get there. If that's too fast, ramp the PWM request to the servo.
radiotech
Mon Jul 09 2012, 08:01AM
Whatever is driving the motor, the input may or may not describe the
position of the shaft.
What is used with machinery today is a shaft encoder. These are called resolvers
and replace the old tach that was used with analog PID loops.
Mon Jul 09 2012, 02:45PM
It's the magic of negative feedback. The "I" term of the PID will make the output go to whatever value it takes to reduce the error to zero.
Say your PID was implemented with 16-bit integers, then the output would have a range of -32768 to 32767. You just need to adapt this to the range of the PWM module on the microcontroller, which might be 0 to 1023, but not all of that range may correspond to valid inputs for a RC servo. So some scaling and maybe saturation might be needed, and as soon as you do saturation you should probably implement anti-windup for the I term too.
If your PID is implemented in floating point, you may want to think twice before using it in an embedded application. And if you don't understand the difference between fixed and floating point, you should probably think twice before trying to write an embedded application. tongue
RC model servos already have a PID loop inside to control the motor so that shaft position (sensed by a pot inside the servo) tracks the input pulse width.
That's all I'm saying without a video :)
AndrewM
Mon Jul 09 2012, 03:41PM
The servos really aren't what he wants to control; he wants to control his vehicle's pitch/roll for which he gets feedback from his gyro and accels. Servos are fast compared to the vehicle dynamics, so generally you'd model them as "perfect"/instantaneous since, as Steve says, they have their own PID controller already.
Patrick, you don't need to do anything special. Develop a function and controller that generates the servo positions as output. Servo position-to-PWM is 1:1 so just translate the output with a simple transfer function.
THAT ONE WAS FOR FREE WHERE'S THE VIDEO!??!?
Mon Jul 09 2012, 08:46PM
Well, you hope servos are fast compared to the vehicle dynamics, but from the video (yay!) the tilt rotor looks pretty skittish. I think the wooden pole needs fastened on tighter.
I guess the way the system works is this: The Kalman filter spits out a 6-dimensional estimate of the vehicle position. (3 translation, 3 rotation.) Or maybe it works with velocities or accelerations, I don't know.
A 6-D vector of the desired position (or velocity or acceleration) is derived from the RC control inputs.
Then 6 PID controllers are used to derive 6 error signals, one for each dimension, which get mixed down in some sort of transformation matrix to drive the servos.
Things are complicated (or maybe simplified? :)) if the craft doesn't have control authority in every dimension. So for instance, a copter doesn't have independent control over translation in the horizontal plane. If it wants to translate, it first has to tilt itself (rotate) so that the downward thrust vector points partly sideways. So rotation and translation are all mixed together. I have no idea how this is handled by an autopilot.
