  • Guests: 49
Does This Sound Right?
currentkills91
Wed Jul 04 2012, 07:46AM Print
I'm testing my SSTC driver (Steve Ward's DRSSTC .5) and half-bridge with a flyback as a load, and for feedback I'm simply feeding a small signal into it, around 100kHz or so. I first started with a 12V supply, moved to 24V, then 36, then 100V, then all the way to full wave rectified mains (170VDC) and the sparks I'm getting from the flayback are amazing...well till it died...
My question is, is what should I be expecting from a typical flyback running with a half-bridge? I have a 10 turn primary and like stated up there, am running it at about 100kHz at 170VDC. I'm getting...was getting about 6 inch sparks till it killed over. (my poor flyback actually started on fire O.o ) Everything in my setup stays cool as a rock, so I'm happy about that.
So what do you think, does 6 inches sound about right for this setup?
Wed Jul 04 2012, 10:02AM
The length of spark you get is really more a function of how much abuse the flyback can stand, than how good the driver is.
currentkills91
Wed Jul 04 2012, 08:08PM
Hmm, I figured I would just get huge sparks till it failed. Maybe I should wind my own and see what I can get?
