  • Guests: 103
PL519 Plasmaspeaker
RateReducer
Mon Jul 02 2012, 04:35PM Print
RateReducer Registered Member #4603 Joined: Wed Apr 25 2012, 07:33PM
My new Plasmaspeaker shades
Finally a loud one...
Regards
Mon Jul 02 2012, 05:00PM
NICE! i wonder if i can do the same thing with my GK-71, its kinda bigger
RateReducer
Mon Jul 02 2012, 08:04PM
Thanks!
Tom Williamson wrote ...
Absolutely. I tried it already. But back then i only had a transformer on the G2 -> not very loud.
Maybe i will try it one more time with a proper modulator.
Regards
Mon Jul 02 2012, 08:22PM
Nice, how do you deal with interference? I wanted to build a similar plasma speaker, but seeing the extreme interference it produces I didn't dare to try it. I also experimented with tube transmitters (which are a similar thing) but the interference messed up my power amp and there was a really huge 50Hz ripple on the output.
Tue Jul 03 2012, 12:25AM
Good job, very nice coil !
The sound is indeed quite loud, and very clean, congrats smile
RateReducer
Tue Jul 03 2012, 06:39PM
@ Dr. Dark Current: Thanks. Which interferences do You mean? The 50Hz hum? Or the interferences that could kill your amp?
@ PhilGood: Thnaks! smile
Regards
Tue Jul 03 2012, 06:48PM
I meant the HF interference capacitively coupled through the audio transformer (or directly if grounds are interconnected), I think it could mess up the connected equipment or even damage it... Proper grounding of xx MHz is not possible in a simple way...
RateReducer
Tue Jul 03 2012, 07:49PM
Okay. I grounded the cage and the core of the transformer on the radiator. Works quite well but there are still some interferences if i touch the cables that go to the amp... But the amp survives ^^
Regards
