  • Guests: 69
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
My First Tube! :D
1 2 3 4
Mon Jul 02 2012, 09:53AM Print
Hey 4hv!
my first vacuum tube has arrived today,
its filiment is 20v @ 3.5A max (GK-71)
ive been looking for a transformer for this but i havent found any so far
anyone got any good ideas on what i can do about this?
thanks,
Thomas
EDIT:
im trying to make the capacitor feedback, how do i cut 0.5mm copper?
Mon Jul 02 2012, 09:57AM
The best way is to rewind one, you can find transformers of such power rating everywhere, just select one which will looks like the core can be easily disassembled.
Mon Jul 02 2012, 10:21AM
Great, had a look through all of my transformers,
most of them are worth too much to rewind or just unsutible (the primary appears to be wound ontop of the secondary)
RateReducer
Mon Jul 02 2012, 03:22PM
RateReducer Registered Member #4603 Joined: Wed Apr 25 2012, 07:33PM
Hi! Nice tube! congrats wink
I found a nice filament transformer in a broken audio amplifier. Works perfect for the GK71 without rewinding. amazed
Regards
Paul_J.
Mon Jul 02 2012, 04:53PM
Paul_J. Registered Member #5436 Joined: Sun Jun 24 2012, 01:44AM
Hi,
Use a slightly underrated 24 volt transformer. With a bit of luck, it should drop down to 20-20.5 volts. It shouldn't overheat with the short run times of a vttc. Or use a suitably rated transformer and a varaic.
Mon Jul 02 2012, 04:58PM
hehe, the only 24v transformers ive got are 1.1KVA 24v-0-24v with a 170v primary
Ben Solon
Mon Jul 02 2012, 05:03PM
how about a smps? if you go with a nice fully built ic like the lt1070 you can easily get that power. plus because it has antergrated fets, the parts count is ~5. i built a usb to power dc-dc for testing of high voltage stuff off of a computer supply. it can out 9-28v at a really nice current rating limited only by the usb 500-1000mA. if you where to power it off of a 12-18vdc source with 3-5A, you'd get your desired specs.
Mon Jul 02 2012, 05:43PM
hmm, my friend linked me to 5 sets of Ferrite core with bobbin (rather large too) for $53 inc P&P
Mon Jul 02 2012, 06:35PM
I wouldn't use a complex and interference-prone SMPS in an otherwise very simple and "forgiving" circuit of a VTTC. But it is everyone's thing I guess...
Mon Jul 02 2012, 08:25PM
im not really too interested in making a entire SMPS so im looking around my room and on ebay for transformers hehe ^~%
