  • Guests: 55
Wires and LEDs by a primary...Good or bad?
Killa-X
Thu Jun 28 2012, 01:39AM Print
For looks I was thinking it would be cool to buy some LED strips (those sticky back, paper thin clad ones) and putting it in each 1/8 primary section. But, could this cause problems with the primary and make the coil not perform?
If its a bad idea, is there any way I can get the same style of effect..?
0Iltz
Thanks!
P.S If anyone wonders why the clear lexan on top, I had a long chat with steve ward. He gave me reasons besides just "keeps the dust off"
Forty
Thu Jun 28 2012, 03:54AM
two problems i can think of:
-If the voltage is high enough on the primary it could arc to the LEDs
-The primary might induce a large current into the wiring for the LEDs
for a similar effect:
-EL wire might work
-individual LEDs with their leads and wiring perpendicular to the primary so minimal voltage is induced in them
-pipe the light in using TIR (fiber optics or more acrylic)
-if you could get some small fluorescent bulbs incorporated neatly, wouldn't they light up when the coil runs?
Killa-X
Thu Jun 28 2012, 04:21AM
Yeah, they would. I think the energy that lights up the bulbs wouldn't be significant enough to really cause any problem. Could be something to look into. Someone suggested me the light tubes before, but id need 1 per section, unless I make a coil ring with it.. my look odd, underneath ;)
Ben Solon
Thu Jun 28 2012, 01:28PM
You could scratch the lexan with a cool pattern, then just shine light from the controlls up to the plexi. That'd be really awesome. Just might do that with mine now that I came up with that!
Thu Jun 28 2012, 03:28PM
I would say as long as the wiring for the LEDs doesn't form a complete loop around the primary, it should be fine. You want to minimise the loop area of the LED supply circuit as far as possible.
Dr. Drone
Fri Jun 29 2012, 12:18AM
shades
Killa-X
Fri Jun 29 2012, 02:40AM
Yeah, but how are they wired. Do you have 1 string of wire going from a power supply to each LED, or just 1 string of wire, and you connect your LEDS in parallel (meaning you have a open circle)
Paul_J.
Fri Jun 29 2012, 04:23PM
Paul_J. Registered Member #5436 Joined: Sun Jun 24 2012, 01:44AM
Why don't you use mini neon bulb instead? NE-2 is cheap on eBay.
