  • Guests: 49
Care for MOT!
Patric
Wed Jun 27 2012, 07:51PM Print
Patric Registered Member #2899 Joined: Wed Jun 02 2010, 06:31PM
That is what I do with my MOTS! I heat them up, and then put them in a tail with pure paraffine wax.
Paraffin wax is an excellent electrical insulator, with an electrical resistivity of between 10^13 and 10^17 ohm metre!
1340826419 2899 FT0 Hstrafo
Tetris
Wed Jun 27 2012, 09:05PM
Woah. But wouldn't the paraffin melt if the MOT gets hot?
Killa-X
Thu Jun 28 2012, 01:49AM
My MOTs have gotten hot to the point that when plastic touched their shells it melted and smoked. I spray painted them with engine enamel so, thats okay! Even mounted them to 1/2" plate of AL...
Patric
Thu Jun 28 2012, 08:21AM
My MOTS keep cool, they are regulated! I know my dear MOTS will survive me!
Thu Jun 28 2012, 09:02AM
The insulation of a MOT is usually rated at 200 °C, with that wax you are greatly reducing its power capability before the wax melts...
cbfull
Thu Jun 28 2012, 01:47PM
Why would anyone need to pot one of those in wax? It's not like you need to supress corona, the voltage is too low for that. It seems like it would just trap heat and cause it to build up.
Also, doesn't paraffin tend to pull away from the windings when it solidifies? It shrinks a great deal when it hardens.
Still, looks really cool.
Patric
Thu Jun 28 2012, 04:13PM
I had flash-overs, and it is a good protection against humidity.
Dr. Drone
Thu Jun 28 2012, 05:58PM
shades
Thu Jun 28 2012, 09:29PM
Dr. Spark wrote ...
1340906255 290 FT140805 Quad700
Great look, really nice !
Patric
Fri Jun 29 2012, 06:55AM
Dr. Spark wrote ...
MOT’s are designed to start saturating at %60 power to protect the magnetron. This means heat will start to migrate out of MOT. Wax is going to melt with our heavy hands on the Variac indeed. The best way to keep the MOT cool is to place them in oil and also insulating from air if running them above their rated voltage in series. Have been running MOT’s (Series and parallel) hard for three years with no issue on Quadzilla.
Spark on,
WOW!
