  • Guests: 36
Capacitive power transfer: how would you approach this?
Thu Jun 28 2012, 12:15PM
I'll try and build something to test it. the keyword here is 'electrostatics'.
Static electricity doesn't require a return path. If there was a return path when you hold a VDG your hair wouldn't stand on end, surely?
EDIT: I'll start another thread if you prefer, if you consider that my comments are 'off topic' in this one.
Thu Jun 28 2012, 12:21PM
That is true, but static electricity can't transfer power. Power is voltage times current, and if the electricity is static there's no current.
Thu Jun 28 2012, 12:28PM
Steve Conner wrote ...
but there is 'movement of charge', there is a 'potential gradient', and a potential gradient can result in a movement of electrons from one place to another. I'll try to devise something to illustrate/demonstrate my point.
Thu Jun 28 2012, 12:59PM
Movement of charge is current. If charges are moving around, it's electrodynamics, not electrostatics. That means you need to consider the displacement current.
In the case of your original circuit, you need to draw a capacitor from one of the top corner nodes back to ground. The circuit won't work without this.
Thu Jun 28 2012, 02:06PM
I'm working on a test setup using my sig.gen. I have to go out later, but I'll post results as soon as I have them. I'm not sure if the sig. gen. will provide sufficient output without amplification, but I'll try this with and without the additional cap. that you suggest.
Pinky's Brain
Thu Jun 28 2012, 05:33PM
Ash Small wrote ...
Strictly speaking it's only an electrostatic effect after the fact ... the moment you touch the VDG electrons flow into you and your hair, the amount of charge which flows into you can be determined by measuring the capacitance of your body (Q=C*V).
I might have made things unnecessarily confusing by erroneously saying the return path is to ground ... positing a capacitance to ground is just a convenient model, there are actually multiple mechanisms acting as capacitance ... some of which are in effect even when the ground is infinitely far away. Basically any conducting body will act as having a stray capacitance to ground and because it acts like that the Murata method works.
Avalanche
Thu Jun 28 2012, 05:36PM
I've been reading some old books recently (ahem) and one talks about charging a metal body using electrostatic induction - ie. non contact.
If a metallic charged sphere (say positive) approaches the end of a metallic non-charged rod, the electrons in the rod will re-arrange themselves so that there is a charge gradient along the rod... (is this re-arrangement within the rod considered a displacement current?) you can then bleed off charge at the non-charge-bound end, but the charge at the other end is bound by the sphere so it stays, resulting in a negatively charged rod when you take away the sphere. If you then threw this rod 50 yards, you'd have an electric current, but I'm not sure what the return path would be...
I've actually forgotten what my point was, sorry! Maybe you could catch the rod and then discharge it, obtaining some power?
Edit - as far as the VDG goes, there's a current the way I understand it, due to ions. Your hair (or breakout point on your head) is ionising the air near it, the molecules of which become charged to the same polarity and are repelled (creating a wind), so to keep the electrons going there must be a current flowing down your arm touching the topload. The return path is simply to ground via the ion wind I reckon.
Pinky's Brain
Thu Jun 28 2012, 05:51PM
The corona current isn't necessary to make your hair stand up though, the initial charge flowing into you is enough for that.
PS. the gravity working on your hair is a source of capacitance from the VDG's point of view.
Thu Jun 28 2012, 06:07PM
Indeed, any time electricity is doing work, like raising your hair, current is flowing and it is an electrodynamic problem.
The rearrangement of electrons in the rod is an ordinary conduction current. Displacement current "flows" between the sphere and the rod.
Thu Jun 28 2012, 06:45PM
Ash Small wrote ...
Initial test just using the sig. gen. and some small capacitors I had lying around (sig. gen. output ~12V, do not produce a measurable voltage (with my DMM) using my original circuit above, but with Steve's suggested additional cap. from one 'top node' to 'ground' (other terminal of sig. gen.) produces 2.2V accross the top capacitor. (I also had a 150 Ohm resistor accross the sig. gen outputs for some 'protection'.
I want to retry this using an AC flyback and large HV capacitors, along with suitable diodes though. In the meantime I may play around with it a bit more.
EDIT: forgot to say, frequency was 1MHz.
EDIT EDIT: When I connect my 'scope accross the top capacitor WITHOUT STEVE'S PROPOSED EXTRA CAPACITOR I'm getting a signal of ~100mV. I'm not sure yet if this means current is flowing WITHOUT a return path, or if it's just interference. I definitely seem to be getting current flowing accross the lower 'transmitting/recieving ' capacitor though.
I need to do a bit more experimental research here.
