  • Guests: 32
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
help with primary tap connector
lokeycmos
Sat Jun 23 2012, 07:49PM Print
lokeycmos Registered Member #2553 Joined: Fri Dec 18 2009, 01:36PM
im looking for some input and advice for a connector to tap the primary of my tesla coil. i have an alligator clip, but it sticks up above the strike rail and it touches the adjacent windings. what have you used for yours? is it OK if the wire that connects to the tap rests on the outside windings that arent being used?
1340480976 2553 FT0 1
1340480976 2553 FT0 2
1340480976 2553 FT0 3
Sat Jun 23 2012, 09:02PM
No it is not OK, it creates a shorted turn that will affect performance of the coil, if not melt the alligator clip. The classic solution is to use a spring clip from a fuse holder.
